If I'm translating this correctly from UK to US you're referring to drum sanders on a drill press. These can be useful but if you're routing with templates I don't think they're necessary.
They could be useful for making templates .............. sanding 1/4 in MDF to the line after you've rough cut it to shape. |
I agree with Jack that a sanding drum in a drill press would be helpful making templates, but you probably don't need to go this route if you do a good job routing with the template. But it could be useful if you need to remove any burn marks or minor chatter that can occur.
For this, you could consider the robo-sander drum, which has a disc on the bottom to allow following a template. Just google it if you aren't sure what I mean. You could actually use this method instead of routing if you rough-cut your body very closely to the template lines. I've used a simialr concept (without a robo-sander) to make a fretboard with a template: ![]() I wouldn't really recommend it instead of routing for the body, though. One of the the problems with drum sanders in the drill press is that the drum loads up pretty quickly, and you need to raise and lower it manually. You also need a fairly large auxiliary table on your drill press to support the body properly. Something like this: ![]() That's why an oscillating spindle sander of some sort is much preferred for stationary sanding: ![]() ...but you can't use a template with those. |
Yes you can use hanger bolts or countersink some carriage bolts through the auxiliary top. Acually I leave an auxiliary table on my drill press all the time. I made cutouts in the new top to match the slots in the metal table so I can still use the customary drill-press hold down clamp (looks like a vise-grip with one jaw). Also, the edges are square so you can use any sort of clamped-on fence to guide your work. Get fancy and cover it with high pressure laminate (melamine or Formica). Just make sure you have room to get your hand behind it to operate the crank for raising and lowering the table.
Ditto on the responses about the sanding drum - great for shaping things like templates, but not really productive for the final workpiece (either it will be too fine a grit to cut anything or it will be a coarse aggressive grit that leaves scratches). Think of it along the lines of a belt-sander: useful in the right situation if you want to hog away material, but not something for a fine finish.
Here's mine......
I made my own from melamine. It's been a while but I think I used contact cement to glue the two layers together. Mine is approximately 16 x 31 inches. I routed a 4 x 6 in. recess in the top layer to accept 1/2 in. MDF inserts. The holes in the corner of the recess are for removing the inserts. The cut-out on the rear right allows clearance for the elevation crank. There's a cut-out on the rear left to allow access to the table lock. The six holes at the front are for the old Black and Decker Workmate hold-down clamps (no longer available). Some other clamping method could be used. If I need a fence, I just use a straight-edge and clamps.
...... ![]() It's attached to the drill press table with carriage bolts, washers and wingnuts. ...... ![]() |
You really have to be patient and let the aluminum oxide or whatever abrasive do the cutting. The bearings in a drill press are not selected with a lot of side to side loading in mind; they're chosen instead to handle up and down loads. So don't let this be your primary means of shaping necks or bodies. Those bearings will fail and are too expensive to be replaced regularly.
Bubban0v |
