Old April 7th, 2008, 03:42 PM   #1 (permalink)
kylef's Avatar
Fender No Load Control
Read up on these as i heard Bill Croom puts these in alot of his custom guitars, so im thinking i want one for my partcaster.
Wanted to know if anyone had this though? any reviews to how good they actually are?
Does it actually have to be a tone control? or can the same pot bought be used in the volume position and work the same as a volume...or are they all just for tone?
wondering whether to buy two so i can put one in my paisley aswell....if it does all it says it does, seems a pretty neat idea to me?
kylef is online now   Reply With Quote
Old April 7th, 2008, 04:04 PM   #2 (permalink)
Rob DiStefano's Avatar
A no-load pot simply has one small end of the carbon resistance strip missing. When the pot is turned fully "on", the wiper runs off the carbon strip and the pot is "turned off", or totally out of the circuit.
No loads are typically used for tone pots, to take the resistance and cap out of the signal path. If used for a volume pot, no signal goes out while the pot is fully engaged.
I almost always use a no load tone pot for Teles and Strats.
YMMV.
Old April 7th, 2008, 04:16 PM   #3 (permalink)
kylef's Avatar
did you change both tone controls in the strats?
well i have no wirings for my new tele im building, so this looks ideal. heard about them alot, but not tried one.
really looks like a great thing, ill get two for my two teles, might try them on my strats later.
Old April 7th, 2008, 04:25 PM   #4 (permalink)
I always wire up Strats with a neck pup blender, so it's a 250k master volume, 250k master tone (no load), 1meg neck pup blender.
The no load tone is perfect for a Strat, so that at higher volumes the bridge pup will really twang out to its max.
Old April 7th, 2008, 04:57 PM   #5 (permalink)
i have a no-load control on my tele and really love it. it doesn't make any major changes, but i like knowing that my pickups' signal isn't being filtered when it's 'on'. i strongly recommend one for your tele
jivetrain is offline   Reply With Quote
Old April 7th, 2008, 06:48 PM   #6 (permalink)
RomanS's Avatar
I have a no-load tone pot on my Thinline partscaster - but frankly, it doesn't do a lot; on my next build I'll use a regular tone pot again.
Old April 7th, 2008, 07:49 PM   #7 (permalink)
Ronkirn's Avatar
I jess ordered a mess of 'em any shop that can order Fender parts can get ya one.... Fender part number is 099 0832 000 that's a 250K
Ron Kirn
A government big enough to give you everything you want, is strong enough to take everything you have. – Thomas Jefferson
Just because you do not take an interest in politics doesn't mean politics won't take an interest in you! -Pericles (430 B.C.)
Old April 7th, 2008, 07:53 PM   #8 (permalink)
blacklinefish's Avatar
The Fender no-load pot has a 'detent' to let you know it has disengaged itself from the circuit. I like this feature, but if you are very intimate with your tone controls it might be a pain to feel that.
I think it adds a little sparkle, you may or may not notice it.
--gh
blacklinefish is offline   Reply With Quote
Old April 8th, 2008, 04:53 PM   #9 (permalink)
I put one in my Tele last year. I think it brings a little extra edge to the tone, especially if you run through a "woodier" tweed amp, or use overwound pickups, which don't tend to be as bright.
Geschwader is offline   Reply With Quote
Old April 8th, 2008, 05:11 PM   #10 (permalink)
SatelliteOrders's Avatar
Just a little googling will point you to no-load pots with no detent.
SatelliteOrders is offline   Reply With Quote
Old April 10th, 2008, 06:46 PM   #11 (permalink)
kylef's Avatar
just ordered 3 :D
one for my paisley, one for my new tele im building, and one spare....ill end up using it in one of strats.
i had a quick look at the swap im going to do in my tele, and it has a green resistor between the volume and tone......will i need to change this resistor to the red one that comes with the no load (i know nowt about this sort of stuff, but im sure its a 0.22 that comes with the no load?), or will it just be case if usoldering the standard tone, and slip in the no-load....as in straight-swap with the pots?
Old April 10th, 2008, 07:45 PM   #12 (permalink)
Originally Posted by kylef View Post
just ordered 3 :D
That's a capacitor, not a resistor. The typical value is .022uf, which is what comes with the Fender no-load pot. Yep, just unsolder the old, solder in the new, no other changes.
Old April 10th, 2008, 08:00 PM   #13 (permalink)
Cygnus's Avatar
I have no idea what any of this means
Cygnus is offline   Reply With Quote
Old April 12th, 2008, 06:39 AM   #14 (permalink)
kylef's Avatar
ha. im still learning! really should have stuck in to physics!!
cheers for that rob!
Old April 12th, 2008, 01:24 PM   #15 (permalink)
claudel's Avatar
This link may be of interest...
How to make a No Load Pot
I've done this a couple of times and it's easier to do than to read...
claudel is online now   Reply With Quote
