Old April 3rd, 2008, 10:00 PM   #1 (permalink)
My new JBtele is humming
My new James Burton tele is humming more than I would expect. It gets worse if I take my hands off the strings. I know all single coils have some hum but these seem real loud. Any suggestions?
Also, when the pickups are fited like this, do you have to remove the neck to adjust the trussrod?
Thanks!!!!!
squeally dan is offline   Reply With Quote
Old April 4th, 2008, 02:12 AM   #2 (permalink)
braderrick's Avatar
kinda sounds like a grounding problem to me, especially if it gets worse when you're not touching the strings. The way those teles are set up with a hardtail strat type bridge I'm not sure how they do the string grounding thing or if you even can. I assume there is nothing on the back side other than string ferrules? Those are lace sensors and they definately shouldn't be very noisy so it must be a grounding issue. As far as the truss rod, if it adjusts at the heel you probably will have to remove the neck unless it looks like you can get a screwdriver in there.
braderrick is offline   Reply With Quote
Old April 4th, 2008, 03:18 AM   #3 (permalink)
three barrel's Avatar
Maybe it just doesn't know the words...
three barrel is offline   Reply With Quote
Old April 4th, 2008, 06:42 AM   #4 (permalink)
controlfreak's Avatar
the way you describe the sound gettin worse when you take your hands off sounds exactly like what was wrong with my 72RI MIJ tele. I took off the pickguard and bridge and soldered a wire running from the back of the tone pot into the pickup cavity. then i put the exposed end of the wire under the bridge as i screwed it back down ensuring that the exposed metal on the bridge made contact with the wire.
it has cleared up the problem for me, no nasty hum anymore.
can anyone validate this method?
controlfreak is offline   Reply With Quote
Old April 4th, 2008, 06:56 AM   #5 (permalink)
Scotland's Avatar
I do that with all my Teles and it really helps.
