#121 (permalink) |
I installed the nut today.
The headstock still needs several coats and sanding in between to hide the decal thickness. ![]() Body is getting close...About 1 pound of Deft on her at this point. Was 4.2 and now at 5.0. Once thick enough and hard enough to sand, I'll knock off the orange peal. ![]() ![]() Edge view.....pretty Gurrrrrllllllll. ![]() |
#124 (permalink) |
I am using the 1 quart cans.....at this point.
I am using a China Bristle brush...high end to paint the body. The paint cans are too full of thinners and accellerators and I need a nice thick coat to do the job. Don't get me wrong....I have 6 more cans of the spray coming but the body needs a thicker coat. Soon....very soon....... The danger is going through the color into the sparkle and ruining the finish. Rough is good at this stage as this is where I was at with the headstock before the decal. You gotta be patient here......success is just around the bend... |
#125 (permalink) |
To be precise......
The spray cans are great in the beginning to get the sparkle to stick but the thicker Deft in the can with a paint brush is where I'm at now. I'm about 1/3 through a can of the liquid after maybe 4 cans of spray. The trick is to get the sparkle covered and sealed and then start the thicker coats. Lacquer makes the bottom layers soft as it merges...... Wait....Wait....and you will succeed. |
#126 (permalink) |
You cannot let the guitar lean against anything as the finish will stick even though it seems hard. I reattached the wood temp neck and rehung it as it started picking up the texture of the towel it was sitting on...
The patience required for this build is immense. BuckoCaster is my hero! The lacquer is thick due to my ignorance. The flake needs to be smoothed out right away and I ignored this aspect and now have to make the finish deep enough to cover it all. I can see the job being somewhat faster if I had a smoother flake base....... My next guitar will have this knowledge in it's build and hopefully the depth of lacquer less to completion...... Love ya BuckoCaster.,..... |
#127 (permalink) | |
Let's just say it is all part of the master plan...you are just a pawn...and leave it like that! That guitar is looking great.
"An awfully lot of time can be wasted waiting for the right time." - Gunsmoke's Doc Adams |
#128 (permalink) | |
I used to be indecisive.... but now I'm not so sure... |
#130 (permalink) |
Stratocaster? Telecaster? MojoCaster! |
#132 (permalink) |
Today is like yesterday, gonna be 93F but dry.
I cleared out the garage and got my mini work bench setup. Today we route the body top for binding and then use my new 1/4 round for the body back. ![]() Body is a 3 piece alder unit pre shaped and routed. 13/4" thick and 4.9 lb in weight. Got her clamped to the bench and started the top route. ![]() A little closer view. ![]() Another view. ![]() |
#137 (permalink) |
Here are the paint and sparkles, looks like they are becoming friends with the body. Ya gotta introduce them to each other and make sure they are compatible.
![]() Got the supplies together in the kitchen, this is where I'll do the binding and the Wife didn't say a word as she loves my SparkleCasters. ![]() All glued and taped up....Let her dry for an hour and tear the tape off to see what I got here. ![]() Yessiree, I sure love to build these lovely Geetars... |
#138 (permalink) |
That bottom picture looks so familiar that I got the chills!
My guess, from the size of that jar, is that you have a LIFETIME supply of those sparkles!
#141 (permalink) | |
I checked my fuschia bottle and I have enough to do 2 more guitars. I bought the big 6 ounce bottles and it only takes less than 2 ounces to do a Geetar body and headstock. I learned that socket trick from you Buckocaster..... I have 6 quarts of Deft and 8 spray cans in my inventory so more sparkly projects are definitely in the future for me. Maybe I can do a fuschia airsoft gun?.......NOT! |
#142 (permalink) |
The binding is done as far as the glue stage. I used my Exacto saw to dispense with the extra material on the ends.
![]() I started the slow process of scraping down the binding to match the body. This binding was too thick for my tastes so I routed shallow and will scrape it down. ![]() There was some interest in my leaving the binding proud on the last build. The problem I ran into is that I have a shallow pool that needs to be filled with lacquer. I guess it's OK on the FuschiaCaster as I left mini mountains of flake all over. On this build, I will try to make the flake height more uniform. It will require a lot more coats of lacquer than a guitar sprayed with the flake but that is the desired outcome. By allowing the flakes to stand on edge and every possible angle, you get a finish that literally looks alive when it is moving. In the sun or under stage lights, this is the result and the extra effort is well worth it. IMHO |
