Old February 9th, 2008, 08:52 PM   #1 (permalink)
Tedecaster's Avatar
Free Radius Gauge
I was surfing through various sites looking for a neck for a friend's guitar & while at USACG saw a link to a site called Pickguardian. They had this cool little PDF for a radius gauge that you print out on cardstock & then cut out. Saves you the troubles of laying out your own.
Radius Gauge
Tedecaster is offline   Reply With Quote
Old February 10th, 2008, 12:20 AM   #2 (permalink)
boris bubbanov's Avatar
I've been meaning to place an order with them, just to show my appreciation for that little guage. It has come in real handy many times.
Maybe a 69 Thinline pickguard.
Old February 10th, 2008, 11:49 AM   #3 (permalink)
e-merlin's Avatar
I've never been much good at cutting on the line. That's why I bought a set!
'tone is in the underpants'
Old February 10th, 2008, 12:02 PM   #4 (permalink)
Thank You Tedecaster for the very cool link.
mitchelguitar is offline   Reply With Quote
Old February 10th, 2008, 07:54 PM   #5 (permalink)
martyb1's Avatar
I bet my buddy with the laser etcher could cut them out of some type of acrylic for me.
Before throwing it out,make sure it's not 16x13x1.75
martyb1 is offline   Reply With Quote
Old February 11th, 2008, 08:15 PM   #6 (permalink)
thanks for posting that, i used them to reset my action. i wonder what the importance of having the bridge radius correct is, though. is the idea just to make the distance all the strings need to be pressed down to fret the same, to make the action seem more even?
jivetrain is offline   Reply With Quote
Old December 21st, 2009, 03:52 PM   #7 (permalink)
DixieChicken's Avatar
Thanks for the tip (link)
Just an idea to make them more durable. I had a few printable cd's lying around which had burn faults in them (unreadable), so I used cd cover printing software to print the templates on them. I carefully cut them out on a fine scroll saw and finished them with a dremel sanding tube. They are slightly larger than the cd from corner to corner but you don't really miss the corners. In actual fact Dan Erlewine recommends cutting the corners off to get them to fit better when the neck is still fitted.
DixieChicken is offline   Reply With Quote
Old December 21st, 2009, 04:24 PM   #8 (permalink)
Bertymoe's Avatar
Very Cool .I have some leftover pickguard material I was just ready to toss.
Bertymoe is offline   Reply With Quote
Old December 21st, 2009, 04:45 PM   #9 (permalink)
I made one many years ago with a pencil compass and some card stock, 4 sided just like these. They are just used for quick reference, so doesn't need to be real durable. I also made one with slots cut out, to fit between the strings of a strung guitar, 7.25 on one side and 9.5 on the other, thinking I could keep it my wallet if I'm at Guitar Center and want to check a fretboard. But it's actually real easy to feel and see a 7.25 or 9.5, so it never got much use.
Dizi is offline   Reply With Quote
Old December 25th, 2009, 08:49 PM   #10 (permalink)
porknblue's Avatar
I'm using the PickGuardian version. Printed them out and lamintated both sides in clear. Then I cut them out. Pretty durable tool.
"I was right! Everything I knew was wrong!"
porknblue is offline   Reply With Quote
Old December 25th, 2009, 09:10 PM   #11 (permalink)
In a nutshell, yes. If your bridge radius matches the radius on your upper fretboard then it's all nice and even. It's not life or death though, if your radius is out by a tiny bit you probably wouldn't even notice.
Dan Erlewine has some great videos out, I recall one on Youtube where he talks about this for a couple minutes. I don't pretend to know anything, hearing Dan tell it would be the way to go.
MondoGuitar is offline   Reply With Quote
Old December 25th, 2009, 09:54 PM   #12 (permalink)
I made one some time ago when I was operating a cnc laser....I was experimenting with different style necks, this let me know which ones I liked....
I'll add a pic later the entire interweb is running slow tonight....at least our end of it!
1962guitargeek is offline   Reply With Quote
Old December 26th, 2009, 12:13 AM   #13 (permalink)
Call me extravagant, but this is WAY too much trouble to go through for an inexpensive tool, i.e. a set of StewMac Understring Radius Gauges.
The Understring version is the only one I use. The underside I use to measure fingerboard radius, and the topside to measure under the strings at the bridge to set the bridge radius correctly.
I am here to tell you that, after having worked on guitars for the past 35 years, this is one of the best setup tools I own, and it makes a GREAT deal of difference in playability of a setup to have the bridge radius match the fingerboard radius exactly, AND to not have to fool with rulers to do it.
John R. Frondelli
"Mediocre" is the new "Good"
jrfrond is offline   Reply With Quote
Old December 26th, 2009, 12:31 AM   #14 (permalink)
John, I am a guitarist who is now starting to work on my own guitars. Can you please recommend the basic tools I will need and any tips you may have on not getting ripped off buying them? I would really appreciate the help, there's a lot of iffy stuff on the internet... Thanks.
Old December 26th, 2009, 09:50 AM   #15 (permalink)
Dan Erlewine has a book called "How To Make Your Electric Guitar Play Great". In the back there is a set of over and under radius gauges you can punch out. They're made of a durable plastic of some sort. The book is only 20 bucks at your local Borders. Well worth it.
Ramblin Ray is offline   Reply With Quote
Old December 26th, 2009, 10:13 AM   #16 (permalink)
FloridaCaster's Avatar
Much Thanks!!
FloridaCaster is offline   Reply With Quote
