Old December 15th, 2007, 12:24 AM   #1 (permalink)
MulliganChebichev's Avatar
Splitting a bucker with a 3 way
Can someone give me the wiring so when using a traditional 3 way and bucker it gives this:
1 - north coil
2 - both coils
3 - south coil
Thanks
MulliganChebichev is offline   Reply With Quote
Old December 15th, 2007, 01:32 AM   #2 (permalink)
micpoc's Avatar
One Humbucker with Dual Coil Tap
micpoc is offline   Reply With Quote
Old December 15th, 2007, 01:41 AM   #3 (permalink)
Originally Posted by micpoc View Post
Thats the function, but I'm not looking for one using a SP3T switch, instead want to use a three way lever.
Old December 15th, 2007, 02:04 AM   #4 (permalink)
micpoc's Avatar
Someone will probably be able to advise you how to adapt that to a three-way, should be a very simple matter.
Old December 15th, 2007, 11:15 PM   #5 (permalink)
This single coil diagram will work if you pretend that each pickup is actually one of your humbucker coils.
http://www.stewmac.com/freeinfo/Elec...es/i-3191.html
Last edited by reddogbass; December 15th, 2007 at 11:16 PM. Reason: hyperlink code
Old December 16th, 2007, 06:05 PM   #6 (permalink)
Capel's Avatar
Or find a wiring diagram for the Avril lavigne tele - thats how it is wired
Capel is offline   Reply With Quote
Old December 16th, 2007, 06:10 PM   #7 (permalink)
Thats how I got the idea, but ten bucks say that the AL is using an import switch (I'm wanting a diagram for my CRL spring switch)
Old December 16th, 2007, 06:18 PM   #8 (permalink)
if you wanted both coils in parallel, the wiring should be the same as a regular tele 3-way switch.
You could also use a standard tele 4-way switch wiring for both series and parallel.
I remember seeing a wiring diagram for 2 pickups in series on a standard 3-way but i can't seem to find it.
DJG105 is offline   Reply With Quote
Old December 17th, 2007, 12:40 PM   #9 (permalink)
Deaf Eddie's Avatar
Series on a standard 3-way
Do you want the middle throw to be series or parallel? I'll draw it up for you...
I drew up a series/shunt/parallel option for a humbucker on a standard 3-way a few years ago and I THINK I posted it. AFAIC, that would be more fun than your one coil or the other idea - I'll see if I can find it.
edit:
Yup, here it is:
Humbucker and a 3-way
YMMV - I been wrong before...
Deaf Eddie is offline   Reply With Quote
