CIJ decal removal?
Hi, I recently bought a candy apple red crafted in japan and I have made extensive mods, new pots, knobs, jack, sanded the sharp fretboard edges, saddles, seymour duncan broadcaster pickup and turned it into an esquire, crazy huh. Now the Crafted decal on the back of the neck is bugging me(maybe next time I'll make a partscaster!) How hard is it to remove the decal? Any help would be most appreciated. Cheers.
So............ you have a CIJ Fender guitar known to be a quality instrument and you want to turn it into something that appears to be a partscaster and thus instantly devalue the guitar. Have I got that right?
. Disclaimer: When I say something.... always ask yourself ..... "What the hell does he know?" I'm just not cool enough to be a Mac person. I'm a PC and Windows 7 was my idea. |
#5 (permalink) | |
or here in the states we have Deft brand lacquer which is nitro but thinner than reranch |
#6 (permalink) | |
Did you see it before you bought it?
Well it's not about devalueing, I just don't like the way the decal looks, I mod all my guitars until they play/look better and I will never part with it anyways. I've done that much to it already that it is worth less than I payed for it but damn it sounds good! Probably should have made a partscaster but I wasn't that confident to put it together!
It's easy. Get some steel wool and start working on that spot until you erase it. Follow that up with some 220 or finer sandpaper. If I recall correctly, the finish is poly, so go get yourself some nice poly rattle can to cover the spot. If you're chicken with semi-gloss, you can get satin finish and polish it up with fine sandpaper and/or car wax. Satin is easier to spray.
#10 (permalink) | |
Sand the neck heel, with fine sandpaper, until the decal is removed, but try to leave some finish below the decal. As soon as its expopsed, you can remove it with naptha, or
continue with 000 steel-wool. Then, use some MinWax spray or wipe-on Poly. A couple of coats, steel wool and buff. You can touch up spots with poly very easily. You'll never know there was a decal there.
PJ "I don't know if it's art, but I like it." |
