Old March 5th, 2007, 02:49 PM   #1 (permalink)
Tele Neck PU in Humbucker cavity... how?
I have a tele neck pickup that I want to mount in a non-pickguard guitar neck position that had a humbucker. I cannot find any conversion rings that will use the four humbucker neck holes and provide a single coil slot that is sized for a tele. I can find them for strats... but not teles. Does anyone make these?
Webfoot is offline   Reply With Quote
Old March 5th, 2007, 03:19 PM   #2 (permalink)
lupowitz's Avatar
I hope it helps.
It is just one of the countless variations they provide, so check the store.
http://cgi.ebay.com/HUM-TO-SINGLE-TR...QQcmdZViewItem
lupowitz is offline   Reply With Quote
Old March 5th, 2007, 05:39 PM   #3 (permalink)
Jack Wells's Avatar
Interesting but they don't specify if they fit Strat or Tele sized single coils.
Old March 5th, 2007, 08:11 PM   #4 (permalink)
lupowitz's Avatar
That's true but I thought if it is Tele than no probs, if it is Strat then a tele neck pickup will fit though a little bit on the loose side.
I am planning to do the same as Webfoot so correct me if I guided him into the wrong direction.
Old March 6th, 2007, 10:53 AM   #5 (permalink)
Im guessing that might be for a strat and not a tele. I have one of these that is angled for a strat. While the one I have is oversized for a tele pickup, the top mounting strat holes are too wide for a tele.
I guess the one on ebay would work if you were not using the top two holes to mount the pickup and was mounting the tele pickup to the body wood.
I am surprised this does not exist anywhere.
Old March 6th, 2007, 02:48 PM   #6 (permalink)
Buy a cheap tele pickguard, place a HB pickup ring over it at the neck position, trace and cut the outline and drill 4 mounting holes and you are done
jeffhigh is offline   Reply With Quote
