Old January 21st, 2007, 09:18 PM   #1 (permalink)
dobro\tele hybrid.
I'm thinking of building one, just for fun. My question is, how hard is it to cut the back off the guitar. inch thick maybe, after I cut the hole for the dobro pan, I want to hollow out as much of the guts as I can. Any ideas, or input?
Billis Magoops is offline   Reply With Quote
Old January 21st, 2007, 10:00 PM   #2 (permalink)
Colt W. Knight's Avatar
Im not sure if I understand exactly what you are saying in your post. Do you want to take an existing tele and carve a place to put a resophonic cone? Doing this would make it extremely difficult install tele pickups. Do you just want it to look like a tele, but with a resophonic cone? Or do you want to merge the telecaster biting sound with the twang of dobro?
Colt
Old January 21st, 2007, 10:10 PM   #3 (permalink)
BritishBluesBoy's Avatar
You mean something like this...??
Picture credit - RelicStrat (Thanks!)
BBB.
Old January 21st, 2007, 10:52 PM   #4 (permalink)
Jack Wells's Avatar
Here's one I did ................ and here's how I did it.
http://www.tdpri.com/telephoto/showgallery.php/cat/588
Old January 21st, 2007, 10:54 PM   #5 (permalink)
yeah something like that. I need to hollow out the body some. Have to cut a hole for the cone, and remove a slab off the back to cut out some excess meat.
Old January 21st, 2007, 11:05 PM   #6 (permalink)
[QUOTE=jwells393]Here's one I did ................ and here's how I did it.
Details or how too's? i have alot of my own ideas here, but imput is always helpful. What kind of sounds do you get out of this thing?
Old January 21st, 2007, 11:14 PM   #7 (permalink)
Jack Wells's Avatar
If you feel you need to hollow out more than the well for the cone you might want to build your own body from scratch............ or you could run a body through a thickness planer and take 1/4 inch off the back ............ then add a 1/4 inch back after you rout chambers. I don't think the additional chambers are worth the effort.
Details???............ Follow the link above.
Sounds???........... Resonator type sounds.
Old January 21st, 2007, 11:37 PM   #8 (permalink)
Dadgummit Jack! Everytime I see that Telenator I almost wet myself! Like as in going through puberty all over again. Stop- will ya? Absolutely gorgeous!
