Super Moderator
Buttercaster Pickup Problem
Hey kids, some of you may have seen the "Buttercaster" thread over on the main page.
I'm having a pickup issue. Bridge pup seems to be working normally while the tone knob is way up. When I turn the tone down, the volume drops off, going completely dead when the tone is rolled all of the way off. Pots seems to check out okay. 0-238 ohms. Tone control controls the neck pup as it should. When I wire the bridge pup to the output jack it sounds jus like it should. The bridge pickup has two ground wires...I am running both of them to ground on the volume pot. I must have something shorting out somewhere...but I haven't been able to track it down. Haven't replaced the tone pot...after all it IS working with the neck pup. Anybody have an idea on what I should try or look for?
"If you can't say something nice... don't say nothing at all." - Thumper the Rabbit "She's not only merely dead, she's really most sincerely dead." - The Munchkin Coroner |
Steve...can you take a close up picture of your wiring? Should be a simple fix... Sounds like your shorting your bridge pickup to ground with the tone pot somehow. Are you sure you have the tone cap hooked up right?....Does the tone control work correctly when you have selector selecting both pickups? If so...when you switch to the bridge only ...the switch must be doing something funky wiring wise...
#4 (permalink) | |
Super Moderator
FWIW, I originally had a 4-way switch in there...and it BEHAVED THE SAME WAY. Then I put a Stew-Mac 3 way in...same deal...now it is doing this with this "Fender" 3-way. If it is the switch, I am doing something VERY consistently. ;-) Here are some pix... ![]() ![]() ![]() ![]() Even though it looks like the center lug on the tone pot might be touching the unused one, it isn't. I'm still baffled...with my feet stuck FIRMLY in the MUD.
"If you can't say something nice... don't say nothing at all." - Thumper the Rabbit "She's not only merely dead, she's really most sincerely dead." - The Munchkin Coroner Last edited by Buckocaster51; December 14th, 2006 at 11:07 PM. Reason: added switch paragraph |
I can't see anything in those pictures that would cause that. I recommend disconnecting the tone cap from the wiper of the tone pot and see what happens then. You may need to undo a few things to break the problem down to the area that is bad.
The volume going to zero with the tone turned down sounds like a shorted tone cap, but then you say it works OK on the other PU. Strange. Are you sure you didn't inhale too much nitro?
Best regards, Terry Downs http://terrydownsmusic.com Equine quadrupeds may be coaxed to the reference of specific gravity but may not be compelled to imbibe thereof. |
#6 (permalink) | |
Super Moderator
I think a few days ago I did disconnect that tone cap...didn't notice anything different...but I'll try it again tonight and take better notes. When I find it, it will be one of those "slap the forehead" moments. Is there anything in the pickup itself that could be causing this? Three wires - 2 from the coil and 1 from what I assume is the baseplate/ground. I did disconnect the baseplate ground from the ground on the back of the volume pot...and that didn't change anything except increase the hum when I'm not touching the strings. Could a couple of those be touching somewhere that would produce these symptoms? Doesn't seem so to me...but then...if I knew what I was doing...this would be working. Thanks for the suggestions guys...
"If you can't say something nice... don't say nothing at all." - Thumper the Rabbit "She's not only merely dead, she's really most sincerely dead." - The Munchkin Coroner Last edited by Buckocaster51; December 15th, 2006 at 10:55 PM. Reason: removed product name |
#8 (permalink) | |
Super Moderator
Does it behave the same way whether the control plate is bolted down or unattached, as in these pics? It is hard to tell, just from the pics, whether there could be any accidental shorts that come into play when the control plate is bolted in place. I see the bypass cap has dangling legs, which could come in contact with something. The tone cap also has a lot of its legs exposed, which could lead to a short, if things got compressed when the control plate is bolted in place. (I've encounted quite a few problems like this. They disappear when the control plate is removed.)
#10 (permalink) | |
Super Moderator
I KNOW it is not the bypass cap...because it was doing it before I put it on. But...it could WELL be some other sort of general sloppiness. I will check it out tonight. But...I am not optimistic about that...as last night I took EVERYTHING off the control plate, unsoldered EVERYTHING...and put it back together...only to have the same problem show up. If it is something like you suggested...I am tremendously talented in being able to reproduce it. Keep 'em coming kids! Cheers Steve Dikkers aka Buckocaster 51
Might I suggest wiring the bridge pickup directly to where the switch would normally connect to the volume pot?
This will determine whether the problem is with the switch and it's wiring or not. If the problem still exists, further troubleshooting will be that much easier. My $0.02 |
#12 (permalink) | |
Super Moderator
Guess what? Tone pot STILL does the same thing. So we have elimanated the switch. Next we'll try Terry's suggestion of removing the tone cap from the circuit. Stay tuned.
Super Moderator
Without the tone cap...surprise...the guitar turns into a One Trick Pony. Volume works. No tone control.
Does that mean I have a bad cap?
#14 (permalink) |
Super Moderator
Replaced the 0.047 mf with a 0.033 mf becuase that is all that I had.
Still the same thing! grrr... I'm going to swap out the pot next...
Super Moderator
Different 250 meg pot.
Still the same thing. I'm beginning to think there might be something going on with the pickup. I am perplexed.
#16 (permalink) |
Super Moderator
So...I measured the resistance of the NECK pickup...about 5600 ohms on my super deluxe meter.
The BRIDGE pickup...the one with three wires...reads OPEN between any and all combinations of the three wires. I'm thinking that I might try a different pickup.
#17 (permalink) |
Remove that second ground wire from the pickup............ you've got nothing to lose at this point.
Better yet, replace the pickup like you're thinking.
. Disclaimer: When I say something.... always ask yourself ..... "What the hell does he know?" I'm just not cool enough to be a Mac person. I'm a PC and Windows 7 was my idea. |
#18 (permalink) |
Super Moderator
That's right...nothing to lose...and GUESS WHAT?
A different pickup seems to WORK! What I don't understand is why the first one even worked at all... I am TOTALLY baffled. Thanks for all of the help guys.
#19 (permalink) |
Super Moderator
Buckocaster,
is that the pickup that surprised you with the 3 wires when you first looked at it? I remember having a pickup mightily cornfuse me when it had 3 wires rather than two and I had almost the same experience... it was a few years ago, I can't remember what i did....
The world is an amazing place. Go poke a whale." nickjd |
#20 (permalink) | |
