Old August 13th, 2006, 05:35 AM   #1 (permalink)
eddiewagner's Avatar
save money, save strings! cheap trick content!
hi guys, i gottta share this. i change strings back and forth on my guitars and cant afford a fresh set all the time. specially fat auges for slide have quite a long lifespan.
to make things easier to fiddle through the bridge, i discovered 30 minutes ago that an empty shaft of a ballpen works wonders. stick it trough, put string in from behind, fidlle both back out: presto!!!!!!!
i dont know if i invented something with a commercial potential or if have been just too stupid to do it till today....
My Drum/Guitar-Duo:
www.Captain-Twang-and-his-Rhythm-Cat.de
Old August 13th, 2006, 03:35 PM   #2 (permalink)
yegbert's Avatar
thanks for the tip
You mean one of these?
That sounds clever. I'll have to hunt one to try. Lately I've been trying to save and reuse strings on the same guitar after parts swaps, and it can be a pain getting them back through the STB holes.
Old August 14th, 2006, 03:12 AM   #3 (permalink)
exactly like that one. just cut the tip off. do it and your pain is cured.
My Drum/Guitar-Duo:
Old August 15th, 2006, 11:47 AM   #4 (permalink)
appar111's Avatar
Nice tip! I'll have to start doing that when experimenting w/ string gauges in the future-- makes it alot easier!
appar111 is offline   Reply With Quote
Old August 15th, 2006, 12:38 PM   #5 (permalink)
Formerly known as Eryque
KokoTele's Avatar
I think it's absolutely guaranteed that you could get StewMac to market that as a special gizmo and charge five bucks for it :)
Parts & Pickups
www.kokoteleguitarworks.com
Old August 27th, 2006, 07:20 AM   #6 (permalink)
kingbee's Avatar
be sure it's empty of ink!
kingbee is offline   Reply With Quote
Old August 27th, 2006, 10:02 AM   #7 (permalink)
SteveY's Avatar
Why would people who can't afford strings BUY one?
SteveY is offline   Reply With Quote
Old August 27th, 2006, 11:39 AM   #8 (permalink)
bwanasonic's Avatar
You might want to try small cocktail/ coffee stirrers. Some of these are like very small diameter straws. If the sleeve doesn't need to be flexible, you could try a short length of brass tubing - I think it comes in pretty small diameters, and is available at craft/ hobby stores.
Kerry M
bwanasonic is offline   Reply With Quote
Old May 14th, 2007, 11:54 PM   #9 (permalink)
yegbert's Avatar
followup to this oldie but goodie
Kerry M
The ink pen refills I found and tried were too big to get through the STB holes in a vintage bridgeplate.
I found a plastic coffee stir stick that works. It's smaller diameter than the pen refill but thick walled so it's just the right diameter and stiffness. I used it on a Squier Tele I had converted to vintage bridge and angle-drilled to reposition just the top end of the STB holes, so the STB hole has a bend just past the ferrule. I insert the stir stick from the top, rotate it when I reach the bend and then it comes through.
The 42 guage wound string of my 9-42 roundwound set is a snug fit in the end of the stick.
Old May 15th, 2007, 10:35 PM   #10 (permalink)
teledude66's Avatar
I thought you meant Cheap Trick the band content...
The fact that no one understands you doesn't mean you're an artist.
teledude66 is offline   Reply With Quote
Old May 19th, 2007, 11:26 PM   #11 (permalink)
and I thought that I was the only one who used coffee straws!!??
ehawley is offline   Reply With Quote
Old May 20th, 2007, 12:29 AM   #12 (permalink)
BritishBluesBoy's Avatar
Me too...
BBB.
Old May 20th, 2007, 03:14 AM   #13 (permalink)
GTO
I can see it all,..... a posh box twenty times bigger than it needs to be, a certificate of authenticity, some instructions, a waiver, and a TDPRI 50th Anniversary Medallion, oh, and a bit of plastic tube. The marketing opportunities are endless. I'd get a patent lawyer in tow now, its a great idea.
GTO is offline   Reply With Quote
Old May 23rd, 2007, 08:51 PM   #14 (permalink)
casterway's Avatar
Here's that Cheap Trick content...
If Meg White can call herself a musician, then so can I.
casterway is offline   Reply With Quote
Old May 24th, 2007, 09:37 AM   #15 (permalink)
...the Threadacaster???
Heaven: A Bassman 410, a good pizza, and a nice lie down ...oh, maybe a Bigsby Palm Pedal as well....
gumbo is offline   Reply With Quote
