Nut replacement - Telecaster Guitar Forum
Old November 30th, 2005, 11:30 AM   #1 (permalink)
charlie chitlin's Avatar
Nut replacement
How scary is it to replace a nut?
I've done it a few times by just putting a block of wood against the old nut and breaking it loose...but never on a Fender where it's 'sandwiched' in.
How easy is it to remove a chunk of wood with the nut?
charlie chitlin is offline   Reply With Quote
Old November 30th, 2005, 11:40 AM   #2 (permalink)
Former Member
mellecaster's Avatar
My 2 cents worth
You'll be pretty safe if you first score the finish, on both sides of the nut w/ an X-acto knife..carefully...and then take a small nail punch, and tap it out Gently from the Bass side...Works for me. :D
Old November 30th, 2005, 01:01 PM   #3 (permalink)
Jack Wells's Avatar
My 2 cents:
A little heat from a hair dryer will soften the glue and make removal a little easier.
Sponsored Links   #
» Random Photo for Guests
'72 Telecaster Deluxe Relic
» Recent ThreadsGuests
Fender Logan Custom Guitars
