Old February 8th, 2013, 07:00 PM   #1 (permalink)
grime99's Avatar
1978' Left Handed Custom - Bridge Pick up swap?
Hi All,
My 78' Custom is going in for a neck restoration and I've got a couple issues I'd like to take care of while she's in. (new bridge/saddles)
But what I need advice on is switching the bridge pick up. I've never been 100% happy with it on its own. It sounds really thin. Mids and lows are really scooped. I use the neck humbucker the most, and occasionally both.
My question is what bridge pickup would pair well with the original 78' humbucker? I don't want to swap the neck too. So I need a single coil that plays nice.
I'm not looking for twang as much as a sustained chime and shimmer.
Any help from this knowledgeable group would be greatly appreciated.
grime99 is offline   Reply With Quote
Old February 9th, 2013, 08:34 AM   #2 (permalink)
Formerly known as Eryque
KokoTele's Avatar
I'd say something like the Duncan Donahue would be a great match. The highs are less pronounced and it's got some girth to it, but still sounds like a traditional Tele pickup. It pairs well with a humbucker.
I'm not sure I've ever heard a Tele bridge pickup that had character you could describe as chime and shimmer, not without some good effects. Have you?
Parts & Pickups
www.kokoteleguitarworks.com
Old February 9th, 2013, 08:53 AM   #3 (permalink)
grime99's Avatar
Thanks Koko Tele,
I think my description is lacking. The chime and shimmer is the end result I would like (I'll use some subtle effects to get there.) Just looking for a PU that will serve as a platform to get there, and also pairing well with my original humbucker.
What you describe is what I'm looking for and a more accurate description.
Thanks!
Old February 13th, 2013, 10:16 AM   #4 (permalink)
grime99's Avatar
Bump,
Any other suggestions?
Old February 13th, 2013, 01:41 PM   #5 (permalink)
The String King's Avatar
I think Kokoteles point is that Tele bridge pickups arent generally associated with what you require.
May I suggest a Tele sized P90? The lower output versions have a nice mid response without being too treble-y. Should pair well with a bucker, although I assume they are wide range humbuckers which are quite dark.
"Try not. Do... or do not. There is no try." - Yoda.
The String King is offline   Reply With Quote
Old February 13th, 2013, 04:19 PM   #6 (permalink)
grime99's Avatar
Thanks string king,
I admittingly do not often use language very well :)
I think Kokoteles definately clarified what I was looking for, was just wonderin if there are any other options for my custom (wide range / single coil)
