Old June 22nd, 2012, 01:05 PM   #1 (permalink)
howlin's Avatar
3-way Switch Question
I'd like to switch out the 5-way switch that I have for a 3-way switch on my 3-pickup Tele as I never use the in-between settings and find it a bit confusing at times when going for the middle pickup. Does anyone have a diagram that would allow me to do this? Thanks.
"Its our limitations that make us individuals" - Bill Frisell
howlin is offline   Reply With Quote
Old June 22nd, 2012, 01:18 PM   #2 (permalink)
Vizcaster's Avatar
The wiring should be the same, assuming that they're both quality switches. If you've got an import switch with a plastic housing and all the lugs in a straight line, then all bets are off since they're not necessarily standardized. If they're both the Oak-Griggs type with a wafer, then the lugs are the same whether it's a three-way or five-way switch - you want a vintage strat switch. The difference is there's no detent for positions two and four, but the solder lugs are actually the same.
Vizcaster is online now   Reply With Quote
Old June 23rd, 2012, 03:16 AM   #3 (permalink)
howlin's Avatar
Ah yes, of course. Leave it to me to make things harder than they really are.
Old June 25th, 2012, 02:52 PM   #4 (permalink)
Vizcaster's Avatar
Ok but whenever you need help making things sound more complicated than they are, just let me know.
