Old June 14th, 2012, 07:06 AM   #1 (permalink)
Calmac69's Avatar
Hi,
I've just ordered a Fender Cabronita and am wondering if fitting the S1 switch is as simple as buying the 500k S1 switch and appropriate knob / button or are there other bits and pieces needed ?
I will not be fitting this up myself, will get a tech to do that but I want to order all necessary parts from Stewmac or similar so I can bung them in ASAP .
Regards
Calmac69
Calmac69 is offline   Reply With Quote
Old June 14th, 2012, 10:10 AM   #2 (permalink)
Phostenix's Avatar
How thick is the top? There is an S-1 that has a longer bushing that can be used with a 1/4" top.
Whatsoever your hand finds to do, do it with all your might. ~ King Solomon
My Guitar Wiring Library:
https://sites.google.com/site/phoste...gdiagrams/home
Phostenix is offline   Reply With Quote
Old June 14th, 2012, 10:13 AM   #3 (permalink)
Phostenix's Avatar
The longer shaft version of the S-1 has a premium price tag attached to it.
http://www.darrenriley.com/shop/cart..._detail&p=2055
Old June 14th, 2012, 10:31 AM   #4 (permalink)
63dot's Avatar
That's definitely not cheap, but still cheaper than buying another guitar for further tonal expansion.
63dot is offline   Reply With Quote
Old June 14th, 2012, 12:27 PM   #5 (permalink)
Phostenix's Avatar
I have a Peavey Strat type guitar that I'm going to put 2 of these in. That's $100 worth of pots. But, I'd rather have the S-1s than push-pull, push-push, or toggle switches....
Old June 15th, 2012, 06:51 AM   #6 (permalink)
Calmac69's Avatar
I think I'll have to wait till guitar is in hand to see what's needed. I didn't consider the depth of cavity / body thickness to determine how long the shaft would need to be ?
Thanks for the responses.
Old June 16th, 2012, 04:32 PM   #7 (permalink)
Tele-b-blaster's Avatar
Please post your findings. I plan to make the same mod to my new black Telecaster Cabronita. Thanks.
Twang is a must!
Tele-b-blaster is offline   Reply With Quote
Old June 16th, 2012, 04:44 PM   #8 (permalink)
mexidev's Avatar
^+1 I was thinking about doing the same.
mexidev is offline   Reply With Quote
Old June 16th, 2012, 04:48 PM   #9 (permalink)
Mightyaxeman's Avatar
Isn't this kind of anti Carbronita. I thought the idea of a cab was to go striped down.
Mightyaxeman is offline   Reply With Quote
