Old May 26th, 2012, 06:39 AM   #1 (permalink)
Rob DiStefano's Avatar
tele bridge pup test guitar ...
an esquire of sorts with a rear port hole for fast pup swaps. just need to make it into a tele with a rear port for neck pups, too.
fretted instrument tech ~ custom partscasters
Cavalier Single Coil Pickups
Molon Labe - come and get them!
Old May 26th, 2012, 10:20 AM   #2 (permalink)
sjtalon's Avatar
handier than a pocket on a shirt !!
sjtalon is online now   Reply With Quote
Old May 26th, 2012, 01:14 PM   #3 (permalink)
bargoedboy's Avatar
Like the scartch plate, wicked.
bargoedboy is offline   Reply With Quote
Old October 29th, 2012, 06:55 AM   #4 (permalink)
jkingma's Avatar
+1
Yeah that looks great Rob.
My test guitar ain't so pretty...
Old October 29th, 2012, 07:25 AM   #5 (permalink)
rear routed for quick pup change outs and circuit connections ...
Old October 29th, 2012, 07:32 AM   #6 (permalink)
trev333's Avatar
perfect... no need to mess with detuning strings and removing bridges..... very handy, Rob...
next best would be a hard tail bridge that just lifts off by removing a few screws...
changing PU's with string throughs is a baitch...;)
"by degrees the flood of music drove all speculations out of his mind. It was as though it were a kind of liquid stuff that poured all over him and got mixed up with the sunlight that filtered through the leaves."
trev333 is online now   Reply With Quote
Old October 29th, 2012, 07:36 AM   #7 (permalink)
Durtdog's Avatar
You should make that model available for sale, Rob.
As often as some guys around here change pickups, it could be a big seller for you.
Where did all these chipmunks come from?
Durtdog is offline   Reply With Quote
Old October 29th, 2012, 08:36 AM   #8 (permalink)
Originally Posted by trev333 View Post
... next best would be a hard tail bridge that just lifts off by removing a few screws...
i tried that, easy enuf to do with a wilkinson tele bridge as it's a dual string-thru and top loader.
moving the saddles forward and leaving them there (intonation is not an issue on a test guitar!) gives free access to the four mounting screws ... but, the strings need to get slacked and capo'd, bridge unscrewed/removed, test pup screwed in and leads routed to the control cavity and soldered or clipped, bridge screwed down, strings brought back to tune - then test the pup.
with pup rear routing, i just screw in each pup and clip on the alligator clips - instant testing.
