Old May 18th, 2012, 12:50 PM   #1 (permalink)
Tuner hole drill reamer ?
Hello i have a warmoth tele neck with schaller tuner holes drilled out. Basically the schaller locking tuners i have don't fit as the hole drilled is smaller further in the hole. So basically i need to make the hole bigger towards the front of the headstock. What drill reamer will i need the schallers are 13/32. Plus how easy is this to do/ what is the process of doing this.
Heres the link which shows how they drill the holes for the schallers i think my schallers require the planet waves holes ?
http://www.warmoth.com/Guitar/necks/tunerholes.aspx
sc1991 is offline   Reply With Quote
Old May 18th, 2012, 02:14 PM   #2 (permalink)
Formerly known as Eryque
KokoTele's Avatar
I find it easiest to use a stepped drill bit for this.
I have a tapered reamer, but I find the stepped bit easier and faster.
Parts & Pickups
www.kokoteleguitarworks.com
Old May 18th, 2012, 02:54 PM   #3 (permalink)
aunchaki's Avatar
The long, narrow-taper reamer is an expensive tool that most of us (non-luthiers) need only once in a while. The whole board should chip in ten cents each and buy one. When a person needs it, they pay the shipping from whoever currently has it, then wait to ship it to the next person who needs it. It's like Tool Socialism!
There was a BOSS AC-2 Acoustic Simulator pedal that made the rounds like that for a year or so, a while back. It got shipped to various people who wanted to try it out. It was such a universally-reviled pedal that nobody ever wanted to keep it! Still, it's a sweet piece of TDPRI lore!
Old May 18th, 2012, 03:41 PM   #4 (permalink)
boris bubbanov's Avatar
For the skilled hand, stepped bits work nice. I use them on other jobs, non guitar jobs all the time.
But for the new hand, I think the $ 10 "hansen" reamer sold by IRWIN is the best choice. It may take a little longer, but the risk of misadventure is way small.
Old May 18th, 2012, 04:46 PM   #5 (permalink)
KevinB's Avatar
The Irwin tool will do it...and there are many similar reamers available in that price range...
The taper is steeper than you would ideally like, but reamers with a shallower taper are very expensive.
Just go slowly, and do a little from one side, then a little from the other to keep it even.
Doing it with a drill bit would be faster but I think I'd definitely want to use my drill press.
Old May 18th, 2012, 05:04 PM   #6 (permalink)
Step bit +1.
I attach a small C-clamp to the shaft as a handle.
"Let's take everything we think we know about solid body electrifying guitars and throw it out the window. Let's start over." ---Leo Fender
PumpJockey is offline   Reply With Quote
Old May 18th, 2012, 05:28 PM   #7 (permalink)
Do i need to use this reamer the tuning peg nearly fits i mean its maybe 2mm maximum probably a bit closer to being flush against the headstock. Does it just require a bit more force ? Im just worried ill break the headstock ? The tuners have single pin mounts (no screws). Would it be possible to break the headstock like this it seems pretty solid. I think with a couple of taps on the back of the machine head will knock in to place. I mean doesn't it have to be a tight fit as there are no screws to hold it in ?
Old May 18th, 2012, 05:49 PM   #8 (permalink)
KokoTele's Avatar
Do not, under any circumstances, force anything.
Do you have holes drilled for those pins? If not, do it. They are necessary.
The hole for the bushing and tuner shaft does not need to be a snug fit. The bushing screws onto the shaft, clamping the tuner to the headstock. The pin keeps it from rotating.
Parts & Pickups
Old May 18th, 2012, 09:20 PM   #9 (permalink)
Vizcaster's Avatar
Sears has reasonably priced 1/2" reamers. good tool to have.
Old May 26th, 2012, 10:12 PM   #10 (permalink)
Look at Harbor Freight, mine was like 4 bucks. Last one in the store but it seems to work. I had to walk every damn aisle in the place to find and I still couldn't tell you, it was toward the right, with what!?
61fury is offline   Reply With Quote
Old May 27th, 2012, 03:41 AM   #11 (permalink)
braderrick's Avatar
Just get a couple from ebay like I did. I cut one down to allow me to ream the string ferrule holes in a body. I gave $3 for them... here
braderrick is offline   Reply With Quote
