Does string ferrule metal type affect tone?
I just discovered that two sets of string ferrules that I have are not magnetic and therefore not steel as I had assumed. I guess they must be brass, or aluminum or pot metal. Are most string ferrules not steel? Does it matter? Trying not to be a cork sniffer here, but I we do know that saddle material affects tone so maybe ferrule material does too.
. "Something entirely new in the electric Spanish guitar field..." |
If you feed them to a civet cat and collect its poop, give them a quick wipe with a non-magnetic toilet tissue, you will fix any tone issues associated with typical ferrule tonal apoplexy.
As you can see, I'm attracted to the absurd just like a magnet.
You need to roll the dice to be in the game. |
My wife actually bought me some of that civet coffee for xmas. Seriously pricey, it worked out about £5 a cup (about $8). It was damn good coffee, best I ever had, smooth as a baby's bum. But £5 a cup in my own kitchen? I ain't that rich.
I suspect it is like bridge pins with acoustic guitars. On certain guitars the difference is obvious and on others not at all. If the guitar is an old friend you may notice it more.
Life's too short to worry, Life's too long to wait.... Last edited by thesjkexperienc; April 25th, 2012 at 01:30 AM. |
#9 (permalink) | |
![]() But the tiny ferrules weigh, what, 5% of what the blocks weigh, if that? At some point you're not going to be able to tell. Maybe if you used plastic ferrules or none at all, then the difference would reappear. |
Glendale seems to think so, they know a little bit about Tele hardware ...
http://www.glendaleguitars.com/String%20Ferrules.htm From their website: "I have designed new string ferrules for Tele style guitars. The ball-end of the guitar string fits nice and snug and almost flush with the end of the ferrule. This makes for much better string contact with the body allowing more vibration through the guitar, adding sustain, brilliance and improving overall tone. You can choose from titanium, brass, cold rolled steel, and aluminum sets or you can mix and match to achieve your own personal sound. For example; aluminum for the low E/A strings, cold rolled steel for the D/G strings, and brass for the high B/E strings. The brass removes harsh overtones from the high strings and adds harmonic richness. The titanium is very well balanced and is a little brighter than brass, it also removes harsh overtones from the high strings and adds harmonic richness. Titanium works very good on all six strings. The aluminum tightens up the low end giving more punch and a touch more volume. The "Retro-Rockets" are direct replacements for vintage-style and American Standard Tele's fitting in a 5/16" hole with a 3/8" countersink." Maybe, maybe not - ?
Spanning 23 years ... http://soundcloud.com/klasaine |
#11 (permalink) | |
Dim lights, thick smoke, and loud, loud music. It's the only kind of life you'll ever understand. Dim lights, thick smoke, and loud, loud music. You'll never make a wife to a home lovin' man. |
#13 (permalink) | |
Life's too short to worry, Life's too long to wait.... |
#14 (permalink) | |
