Old April 18th, 2012, 10:16 PM   #1 (permalink)
Phil_tre's Avatar
vintage tuners sound wise ?
Hi !
Is there a difference in sound between vintage Gotoh tuners
and standard modern tuners from my MiM or AM Strat ???
Thanks !
I hope that it's not a stupid question
Philippe
Phil_tre is online now   Reply With Quote
Old April 18th, 2012, 10:41 PM   #2 (permalink)
soulman969's Avatar
Nope......although somewhere I'm certain someone will say they can hear a difference. Probably the same folks who can hear the differences between caps of the same value but of different material.
Oh, there I go starting that up again. LOL
CS 51 Nocaster, "Nashcaster"/Nashville>Nocaster conv., MIM>Nashville conv./Onamac Tall Blues pups, Squier CVC/Keystones pups, CV 60's Jazz Bass, Matt Freeman PBass/Wilde P46 pup, Taylor 414CE. Roland Cube 40xl, Bugera v5, Roland BC 60, tc BG250, GK MB112.
soulman969 is offline   Reply With Quote
Old April 18th, 2012, 10:42 PM   #3 (permalink)
BritishBluesBoy's Avatar
No.
BBB.
Old April 18th, 2012, 10:48 PM   #4 (permalink)
Formerly known as Eryque
KokoTele's Avatar
It's not the tuner that makes the difference so much as the mass, and it is noticeable. The attack is different, the sustain is different, less of an airy snap and twang.
If that's the only change you make to the guitar, the difference is subtle and you may or may not notice the difference when playing with a band.
And I don't believe that different caps of the same value sound different.
Parts & Pickups
www.kokoteleguitarworks.com
Old April 18th, 2012, 11:05 PM   #5 (permalink)
soulman969's Avatar
Glad you brought that up Koko. Now that you mention it I guess I can hear some difference between those on my Nocaster and the ones on my MIM. I'd attribute that to the pickups and the bridge more than anything so maybe it really isn't noticeable as far as the tuners are concerned.
Old April 18th, 2012, 11:15 PM   #6 (permalink)
Stubee's Avatar
It is not a stupid question at all but I'd first play with your guitar's tone & volume knobs, the same on your amp(s), play with pedals if you like, try some different picks (huge difference for the buck) and then forget about the tuners for the rest of your life or maybe just dream about them as far as tone is concerned.
I like vintage Kluson style tuners because I dig the post string hole + light weight, but had guitars with heavier Grovers etc. that sounded great and sure didn't take them off in a tone search.
I am probably completely wrong on this but that's my take.
Stubee is offline   Reply With Quote
Old April 18th, 2012, 11:30 PM   #7 (permalink)
Bartholomew3's Avatar
I have a 68 tele that originally had el cheapo Fender diagonal tuning keys and a couple got wacked out on the road so I had a luthier install a set of Schallers.
Not a huge difference but think I got a bit better projection & sustain due to added mass. It didn't get neck-heavy but I also have an SG so probably wouldn't notice it much.
The Schallers are 40 years old now and a couple of the interior gears are chewed-up so it's time for a replacement but they still work well enough to gig with.
Was thinking of going back to the original tinny Fender diagonals but probably won't. Was not impressed with them.
Bartholomew3 is offline   Reply With Quote
Old April 19th, 2012, 01:43 AM   #8 (permalink)
boris bubbanov's Avatar
I can't tell with the caps. I can't even tell sometimes when the cap is a slightly different value. I can't even tell sometimes if the pot is a different value.
But the tuners, they do matter. At least the way I do them. I've got the string breaking promptly down to a lower point, and the string is prepped and loaded in my own particular way. I don't get the trashy sounds associated with lightweight zinc alloy tuners, and I don't get the ponderous weight and delayed attack associated with big suckers like the Schaller lockers. The whole balance of the guitar is changed, going to a small and light tuner weighing only 5.5 ounces per set. Lighter tuners mean the neck can be thicker and fatter, and then in turn the truss rod can be minimal size and the guitar can go places and be stored places without so much worry; and it can remain stable with much heavier strings and I love how those sound.
People who can't tell haven't learned to properly load a Gotoh split, or they're just lazy.
I forgot to mention superior tuning stability. I forgot to mention the strings sound new much longer. I forgot to mention that the lightweight tuners and great stability mean the relief can be less and thus the bending effort is less.
Can I stop now, or must the beat-down continue?
Philippe, this is not a worry for you Strat guys but the Tele guys do need to do some basic checking on American Tele necks with stock die casts. Mock up the tuners and make sure the top one's mount does not fall over the end of the headstock. Some individual necks will have been sanded too much and I suppose you'd have to trim the mount back or it could snag on clothing, etc. Look at these, I think these are average:
Old April 19th, 2012, 06:24 AM   #9 (permalink)
soulman969's Avatar
Boris I've gotten an education and I won't speak so quickly next time. Koko made similar points. I have the vintage style split shaft tuners on three of my four Teles but one is a CS Nocaster, another is a Nocaster conversion of an MIM Nashville Deluxe and the other is a CVC. Different pickups on one than the other two, three different necks and two different bridges. The fourth Tele is a 95 MIM with the Ping tuners you identified for me to answer my question.
I guess my concerns at that end of the guitar have never been as great as the other but from now on I'll pay more attention to that end and try to learn more about the tuner sets. I spend more time thinking about my strings and my pickups than I do the rest of the instrument and because of the differences between each one of mine I'd never know how much of that was coming from the tuners anyhow.
Time to get smarter. Never to old for that. Thanks for the beat down.
Old April 19th, 2012, 06:53 AM   #10 (permalink)
Odd this has come up .On my Epiphone Dot I made a lot of upgrades ,pickups ,bridges ,pots ,caps etc .I kept the same strings on where possible after the stoptail had been changed .All made quite a difference in not only sound but resonance .I had also done a thorough fret and nut job plus truss rod adjustment .The last item to be changed was to Grover Deluxe tuners ,heavier than the stock ones and much more precise solid feel.The tone and resonance improved by a quite noticable margin,not a huge amount but there ,more clearer bass notes and such .It also stopped the last remaining minor rattle thet epis have and Gibsons dont .I kept the old strings on as usual as its useless putting new strings on twixt before and after .
musicalmartin is offline   Reply With Quote
Old April 19th, 2012, 08:56 AM   #11 (permalink)
Phil_tre's Avatar
Thanks everyone !!
I'm gonna try the vintage tuners on my AM Strat and will let you know
if I can hear a difference. I cannot compared caps of the same value
but I can hear the difference with strings break angle...
I just don't want my Strat to sound twangy / with a very sharp attack
like my Teles w/ those vintage tuners...
Phil.
Old April 19th, 2012, 09:06 AM   #12 (permalink)
Astro1176's Avatar
It makes sense that as an anchor point of the strings, the tuners would be vital to the tone of the guitar. I have changed tuners on 3 guitars, on two (changing from standard modern budget tuners to schaller gotoh locking) I didn't notice any change.
On a Vintage/Wilkinson SG copy I upgraded the Wilkinson Deluxe Vintage Kluson style pickups for solid Sperzel locking tuners and that did make a big difference to the tone. This did change the tone and made it maybe more solid sounding. It wasn't all good, I felt the vintage style tuners had more character and airiness. I hadn't been looking for a sound change and didn't welcome it, but I decided for me the sound was different but good, and worth it for the more precise and locking tuners.
(Can't tell the difference in sound between caps, or between nitro and poly, FWIW)
Astro1176 is offline   Reply With Quote
Old April 19th, 2012, 09:28 AM   #13 (permalink)
The Gotoh SD91 diagram any help
Tuxedo Poly is offline   Reply With Quote
Old April 19th, 2012, 09:43 AM   #14 (permalink)
KokoTele's Avatar
Originally Posted by philqc View Post
Thanks everyone !!
Phil.
There are many components that contribute to your guitar's sound, and no matter what you do, you're not going to get a Strat to sound like a Tele.
The heavier mass tuners contribute to a sharper attack.
If you install vintage tuners on a guitar with modern ones, you'll need a set of conversion bushings.
Parts & Pickups
Old April 19th, 2012, 09:51 AM   #15 (permalink)
OMG. What a torrent of misinformation. There's a lot of things that can affect your tone but your tuners are not one of those things - unless they're so bad that your guitar will not stay in tune.
A well-fitted bone nut will do more for your guitar's tone than any tuner change ever could.
Arbiter is offline   Reply With Quote
Old April 19th, 2012, 02:34 PM   #16 (permalink)
soulman969's Avatar
Funny how the guys who build and repair them disagree with you. Just because some of us have just never noticed any difference doesn't mean it's not there.
Old April 19th, 2012, 02:49 PM   #17 (permalink)
drvoodoo's Avatar
Lots of opinions and different experiences in this thread. I have never noticed any change in tone or sound when changing tuners that I can say is due to the tuners only. Since I ususllt change also the strings that has an effect, if I do not change strings but just unwind and rewind that has an effect etc. Others might hear other things and notice things I do not. Best thing to do is just try it and listen for difference? And, most important, get good ones and wind the strings well so the guitar stays tuned.
drvoodoo is offline   Reply With Quote
Old April 19th, 2012, 03:00 PM   #18 (permalink)
Sweet Jesus, soulman, I've been fixing 'em since 1985 and worked as a builder at Santa Cruz Guitar for most of the 1990s. I'm one of the guys who build and repair them. And I'll say it again - unless they're mechanically damaged, tuners are just not that big a deal, tonewise.
Want bang for the buck? Get a properly fitted bone nut and a GOOD bridge. Those two items will do more than any other mods to get your guitar sounding as good as it can.
Old April 19th, 2012, 06:27 PM   #19 (permalink)
KokoTele's Avatar
I agree wholeheartedly that the nut and saddle contribute more to a guitar's tone than the tuners, but it's simply false to say that they have no effect.
Parts & Pickups
Old April 19th, 2012, 06:43 PM   #20 (permalink)
ludashoeless's Avatar
hmm well my tele sounds different than my strat and they have different tuners.... so.... i can hear a difference
Oh ya Nigel? Mine goes to 12
Originally Posted by BobbyZ View Post
Heck I'd like to see dynamite legalized.
Sure it would be very noisy but think about it in Darwin terms.
'11 Am std strat>blues deluxe reissue
ludashoeless is offline   Reply With Quote
