#22 (permalink) |
![]() Poster Extraordinaire
gotta love this information age millennium, where the hype and bs continues to florish at epidemic rates.
in passive guitar circuits, all that matters for capacitors is value, tolerance and build. don't be clueless - save the pio, bumbershoot, audio boutique caps for real electronic circuits, like amps.
![]() fretted instrument tech ~ custom partscasters Cavalier Single Coil Pickups Molon Labe - come and get them! |
#24 (permalink) | |
I agree with Fezz.
the now mandatory =====> |
#26 (permalink) |
To clarify my rather long post and answer the OP, as others have said, it is a lot of nonscens. If you feel the need to use a specific type of cap do that, but it does not really affect tone IME. I'd rather save that money a couple of PIO costs and get myself a Ron Kirn tele-template set (yes, prices in Sweden for the more expensive PIO caps are high. 4-5 of Jensen PIOs = one set of Kirn templates.. ) No affilation to Kirn
#29 (permalink) | |
Wayne, which brand of Paper and Oil are you using?
I owe my life to Jesus |
#30 (permalink) |
What's the best? Whatever you think it is. If you believe it to be best, then it is.
How will you know? Try it. Try anything you like. It's your guitar, there are no "rules".
"Just once I'd like to hear you scream in pain" "Play some RAP music" |
#31 (permalink) |
I don't use ceramic because they absorb moisture and change value with the weather, plus they are brittle and bits fall off, plus they are small with thin small wires which tend to break off easily.
I don't use PIO because they leak and make a sticky mess. Old wireless radio sets are full of these nasty things. If you must use them then do test measure their value because they are not stable. I use either "orange drop" polyester at 17p.ea or axial polyester at 37p.ea Don't get ripped off. There's a huge electronics industry out-there, these things are as cheap as chips. Only use genuine snake oil. Values from 5nF (treble bleed) to 220nF (super mud) - normally 22nF strat or 47nF tele Why does a strat use 22nF? - because there are two tone controls in parallel to 44nF when both in play. Also use 22nF on 2+2 control systems for same reason. Do experiment with different values ...
#35 (permalink) |
I love these threads. When I put my first guitar together I agonised for ages on what caps to use - Yet I never use my tone control on my guitar, I do it all from my amp and my pedals. What a dufus.
#36 (permalink) |
Just an old mausoleum about 5 minutes from where I live. I took 3 photos of it. I'm planning on going through a bunch of old churchyards and cemeteries near where I live.
Though when I read up online about opening times all I could find were times to go dogging or cruising in them. Add that to the fact I don't own a camera means I'm not doing it until I have a buddy to go with me. ![]()
#37 (permalink) |
http://www.seymourduncan.com/tonefie...ize-your-caps/
that’s a pretty good article… go read it…. Please…… I have posted this analogy several times… In the passive circuits in our guitars, “passive” meaning no external electricity is supplied, the capacitor at the most basic application, and most sonically noticeable, understanding is similar to a hole in a garden hose with a faucet attached. As you open the faucet, here representing the tone control, It allows high frequencies to escape to ground…. They are absolutely gone, not recoverable, turning the tone controls on the amp does not add them back, it only further “shapes” those frequencies that did not escape. The shape of the hole in the hose will not impact the water that remains in the hose… similarly, the “supposed” quality of the capacitor, allowing frequencies to escape will not impact the frequencies that did not escape. The quality of a capacitor does not impact the quality of the tone in a guitar’s circuit… it cannot. A capacitor does not have a “sound” it has a value, and it is that value that represents how big the “hole” is that is allowing the highs to escape. Capacitors are manufactured to a tolerance… a value is stated, say, .047 and the cap is considered OK, if it falls anywhere within a range, expresses as a percentage. So a .047, might actually be a few microfarads above or below the stated value. It is those variations that cause the subtle tone difference when two caps of similar values are compared. That’s it…. While the most comprehensive discussion of the brief explanation I offer is actually real “rocket science”… as it applies to the astounding simple circuits in our guitars…it’s somewhat more simple. Now for the nay sayers….…. In ACTIVE circuits… one that has power supplied, like your amp, a capacitor’s function has a greatly expanded function, and can perform a number of seemingly unrelated functions. In these circuits it does far more than simply provide a “hole” for frequencies to escape, so the type of construction can have a significant impact. However, we aren’t talking about the amp. We’re talking about the guitar. AND…Actually, changing the caps in an amp, CAN result in a substantial improvement in sound…. IF YOU LIKE the resulting sound, “like” being the key word. Remember, for anything you do to be an improvement, or an upgrade, you gotta like the resulting sound. You can spend thousands in “stuff” to upgrade your guitar, and if you don’t like the resulting sound, it’s hardly an upgrade is it… it’s just an expensive learning experience. Ron Kirn
“Silence in the face of evil is itself evil: God will not hold us innocent. Not to speak is to speak. Not to act is to act.” — Bonhoeffer www.ronkirn.com |
#38 (permalink) | |
Oh, about caps, someone tell dude that this discussion is a no-no around here. Oh, no. Mr. Kirn already got to him. Too late. . . . and, "uuuuuuuuuuhh, weiner", huh-huh. There-I said it, Beavis. |
#39 (permalink) |
Bubbalou,
I've used a variety of PIO caps in guitars. I really haven't tried any that didn't sound good, and warmer/richer than polyester types, which tend to be second best to my ears. The new-production Jensens sound great to me - I haven't done a-b testing to be able to decide whether the RS ones are any different than the ones at Angela Instruments, nor can I say whether the aluminum versus the copper ones sound different from each other. The cheaper Russian ones (that you can buy repackaged under the Luxe brand for a lot more money) also sound good, though I may like the Jensens slightly better. I've got a few old Sprague bumblebees and black beauties, when the capacitance measures in the right ranges they seem to add a little extra harmonic complexity, especially when the tone control is cranked down to "woman tone" area. I've never spent more than $20 on a cap and most of them have been a lot less than that - in the $5 apiece range for the Russian ones and random/not much at all for old bumblebees and black beauties, I've just bought batches of old caps and fished them out. Given how much guitar parts cost (it's easy to spend over $100 on a pickup), I don't see the cost of a cap or two as significant. Of course, many here will say that I can't possibly hear what I hear, so for those of you who fall into that camp, please ignore the above. It's not for you. I'm not trying to sell you anything, though I am trying to get you to try a bunch of different composition caps when you're setting up your guitars, to see whether you like the sound of your guitar better with one or another. If you don't hear a difference then don't pay this subject any mind. |
#40 (permalink) | |
way back in the dark ages i also bought in the boutique cap nonsense, amongst other silly guitar notions, but real world testing in laboratory scenarios proved otherwise. all that matters for passive circuit caps is value, tolerance and build. in a blindfold test you wouldn't tell the difference. really. i've tried and so have others, folks who are audio engineers and audio freaks. none could call the pio out of 5 other poly/film caps. seriously. and if you CAN hear a cap difference, there's an anomaly you haven't spotted - look for it, you'll find it. been there, done that. just sayin' ....
