Old April 11th, 2012, 10:53 AM   #1 (permalink)
Barbarosa's Avatar
4 way switch concern
I'm looking to replace the pickups in my tele. I currrently have fender noiseless pickups in it with a 4 way switch and want to go with something like fender OV's or SD antiquities. The tech at a local music store is telling me hat if I install those pups I will have to lose the 4 way switch. I'd like to keep the 4 way. Is the tech right about losing the 4 way switch?
That is a logical conclusion to a misspent life.
Barbarosa is offline   Reply With Quote
Old April 11th, 2012, 11:02 AM   #2 (permalink)
Formerly known as Eryque
KokoTele's Avatar
Yes and no. In order to use a 4 way switch, you need a separate ground for your neck pickup cover. Most pickups do not come with a separate ground, but it is not a big deal to add that separate ground wire. It will probably void the pickup warranty if they don't do it for you at the factory, though maybe certain manufacturers will allow the tech at a dealer to do it. I've never asked that question, but maybe I should.
Hard to believe the tech didn't say he could add that ground wire for you. Probably time to find a new tech.
Parts & Pickups
www.kokoteleguitarworks.com
Old April 11th, 2012, 11:06 AM   #3 (permalink)
Barbarosa's Avatar
Thanks for the response Kokotele. I've already run a separate ground from the pickup cover on the noiseless neck. He was telling me that the 4 way was impossible because the fender noiseless were humbuckers and the OV's are single coil.
Old April 11th, 2012, 11:56 AM   #4 (permalink)
KokoTele's Avatar
Wha? I really think it's time to start consulting a new tech :-) That's just silly.
Parts & Pickups
Old April 11th, 2012, 12:27 PM   #5 (permalink)
telex76's Avatar
For sure.
telex76 is offline   Reply With Quote
Old April 11th, 2012, 12:36 PM   #6 (permalink)
I've got OV's with a four-way. Excellent set up, works just fine. Get a new tech.
Dim lights, thick smoke, and loud, loud music.
It's the only kind of life you'll ever understand.
You'll never make a wife to a home lovin' man.
Ricky D. is offline   Reply With Quote
Old April 11th, 2012, 01:28 PM   #7 (permalink)
sjtalon's Avatar
sjtalon is online now   Reply With Quote
Old April 11th, 2012, 01:59 PM   #8 (permalink)
Barbarosa's Avatar
The guitar tech has been summarily dismissed and been advised to remove his cranium from his rectum. Thanks for the input guys!!
Old April 11th, 2012, 07:00 PM   #9 (permalink)
73Fender's Avatar
Me too, not a problem. And the tech has some strange info going.
73Fender is offline   Reply With Quote
Old April 12th, 2012, 01:40 AM   #10 (permalink)
soulman969's Avatar
Good move. I don't whether you're interested in them or not but as another alternative you could also look at a set of Keystones which already have a separate ground wire attached.
CS 51 Nocaster, "Nashcaster"/Nocasters, MIM Nashville/Onamacs, Squier CVC/Keystones, CV 60's J Bass/Wilde J45s, Matt Freeman PBass/Wilde P46, Taylor 414CE/Fishman Blender, Roland Cube 40xl, Bugera v5/820H, Roland BC 60/CRex, tc electronic BG250 Bass Combo.
soulman969 is offline   Reply With Quote
Old April 12th, 2012, 02:08 AM   #11 (permalink)
DavidP's Avatar
What KokoTele said...
that fellow doesn't deserve to be called a 'tech' given what he's telling you is totally inaccurate ( as well as demonstrating little understanding of fundamental pickup electronics--and that's not rocket science!)
Stay well clear of him and learn to DIY (as well as keeping asking questions around here!)
barely in tune and teetering on the brink of oblivion...
DavidP is offline   Reply With Quote
