Old April 10th, 2012, 09:26 AM   #1 (permalink)
Bridge grounding - is it necessary?
Hi
I’m building a Tele and am using the surgical tubing that came with Pickups I put in my other Tele as I don’t have any springs – I appreciate that the ground passes through the strings but............
I want to ensure that I have as good a ground as I can so have soldered a wire to the back of the bridge which I’ll solder to one of the pots.
I’ll also be shielding all of the cavities (don’t mind hum at rehearsals/gigs but want to minimise it for home laying or recording
Could they above create a ground loop? Am I going over the top?
Billy Porter is offline   Reply With Quote
Old April 10th, 2012, 10:02 AM   #2 (permalink)
Should be ok.
Alternatively feed a ground wire under the bridge and strip about an inch off the end. When the bridge is screwed down it will make a good ground connection.
Tuxedo Poly is offline   Reply With Quote
Old April 10th, 2012, 04:51 PM   #3 (permalink)
Jazzy Jay's Avatar
I did not shield my esquire's cavities, and I didn't solder a ground wire to the bridge. The guitar's dead quiet.
"No bikinis, mini-skirts, skimpy see-throughs or sexually exploitative attire allowed. Except on women."
Willie Nelson
Jazzy Jay is offline   Reply With Quote
Old April 10th, 2012, 04:58 PM   #4 (permalink)
Bridge grounding allows your body, when you are touching the strings, to act as a shield against noise generating external signals. The vast majority of electric guitars have bridge grounding for that purpose.
You will /can not create a ground loop in the wiring of your guitar.
"Life is mostly Froth and Bubble" Adam Lindsay Gordon
chezdeluxe is offline   Reply With Quote
Old April 10th, 2012, 05:05 PM   #5 (permalink)
What are you using to shield the pickup cavities? If you're using copper foil, just extend a strip from the bridge pickup cavity to under the bridge plate, fold the end back on itself so it's raised a tiny bit and screw the bridge plate down on top of it. This way, you won't create an indentation on your guitar body by squashing the wire with the bridge plate. I shielded all the cavities on my partscaster tele and it's dead quiet.
dilver is offline   Reply With Quote
Old April 10th, 2012, 05:10 PM   #6 (permalink)
soulman969's Avatar
Originally Posted by Tuxedo Poly View Post
Should be ok.
+1 This is an easy way to do it. Then just ground to a pot or the cavity itself if it's shielded.
CS 51 Nocaster, "Nashcaster"/Nashville>Nocaster conv., MIM>Nashville conv./Onamac Tall Blues pups, Squier CVC/Keystones pups, CV 60's Jazz Bass, Matt Freeman PBass/Wilde P46 pup, Taylor 414CE. Roland Cube 40xl, Bugera v5, Roland BC 60, tc BG250, GK MB112.
soulman969 is offline   Reply With Quote
Old April 10th, 2012, 08:40 PM   #7 (permalink)
JohnS's Avatar
Yes.
JohnS is offline   Reply With Quote
