Old April 5th, 2012, 11:28 PM   #1 (permalink)
Papa Joe's Avatar
I need diagram for weird 3 way
I've searched for a diagram and didn't find any info at all..This is one strange switch..7 pins numbered 1-7...got the pups to work individualy but haven't figured how to make both work in the mid position..Anyone here know where I can find a wiring diagram??Thank you...PJ...
Name:	3 Way Switch 001.jpg
ID:	122624   Click image for larger version
Name:	3 Way Switch 003.jpg
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body,but rather to skid in broadside,thoroughly used up,totally worn out,and loudly proclaiming:"WOW,what a ride!"
Papa Joe is offline   Reply With Quote
Old April 5th, 2012, 11:33 PM   #2 (permalink)
sjtalon's Avatar
I believe that is a 5 way right (Strat) ??
Squier Affinity
1 - Middle positive
2 Neck positive
3 tied to 4 (jumper)
4 Common / out to Vol
5 N tone
6 M tone
7 Bridge positive
sjtalon is online now   Reply With Quote
Old April 5th, 2012, 11:40 PM   #3 (permalink)
Papa Joe's Avatar
No it's not a 5 way...It's a 3 way..I did determine that,
2=neck
3=output
7=bridge
tried jumping 3 to all the others but nothing worked..
Old April 5th, 2012, 11:41 PM   #4 (permalink)
sjtalon's Avatar
Oh ya sorry, I did hear of YKE Strat ones. Funny it's a 7 terminal, that is what their 5 ways are.
Had this from Deaf Eddie:
bridge pup is connected to 6 and 7;
the neck pup is connected to 1 and 2,
lug 4 is connected to the volume pot.
Lugs 3 and 5 remain OPEN.
May work with that 3 way ??
Hook it up with test leads and give it a whirl.
Old April 5th, 2012, 11:53 PM   #5 (permalink)
Papa Joe's Avatar
Thank you. I'll give it a whirl tomorrow morning..Can't tonight ..Already took my meds..
Old April 5th, 2012, 11:54 PM   #6 (permalink)
sjtalon's Avatar
ubetcha my Wolverine friend !
Good luck !
Old April 6th, 2012, 02:42 AM   #7 (permalink)
Papa Joe ? A weird three way ? This thread is useless without pics.
"Life is mostly Froth and Bubble" Adam Lindsay Gordon
chezdeluxe is offline   Reply With Quote
Old April 6th, 2012, 07:29 AM   #8 (permalink)
sjtalon's Avatar
ahhhhhhhhhhhhhh, is there something wrong with your monitor, or are you just to far away to get them ?
Old April 6th, 2012, 07:50 AM   #9 (permalink)
RocknDrTom's Avatar
Is it possible to turn the switch on an angle where you can look at the connectors inside? I would imagine that the centered pin (#4) is always connected, so that would go to the volume pot. The other ones, if they can't be seen, I'd test with an ohm meter to see which is connected in which position.
RocknDrTom is offline   Reply With Quote
Old April 6th, 2012, 08:17 AM   #10 (permalink)
Papa Joe's Avatar
Now now,behave yourself. Sit up straight and keep your elbows off the table.
Old April 6th, 2012, 08:18 AM   #11 (permalink)
Papa Joe's Avatar
The naughty boy was just yankin' our chain..
Old April 6th, 2012, 08:25 AM   #12 (permalink)
Papa Joe's Avatar
No, the board is well concealed, can't see inside..I've checked with a meter and found the tabs for bridge, neck and output.I just need to find the way to get both on at the same time in mid position.
I think that sjtalon gave me the answer..I'll know in a few, after the caffine kicks in..
Old April 6th, 2012, 09:25 AM   #13 (permalink)
sjtalon's Avatar
Oh I see, inside joke
Old April 6th, 2012, 09:28 AM   #14 (permalink)
dsutton24's Avatar
Here you go:
Yet another hobby that is completely out of control...
dsutton24 is offline   Reply With Quote
Old April 6th, 2012, 09:33 AM   #15 (permalink)
sjtalon's Avatar
I think this YKE switch is different than the import used on the Squiers (CV)
Old April 6th, 2012, 10:58 AM   #16 (permalink)
Papa Joe's Avatar
Problem solved thanks to sjtalon for getting me aimed in the right direction..You had it almost right neighbor...Bridge goes to pin 6 and 7..neck to 1 and 2....but the output has to be connected to both pins 3 and 4.. Works just fine..
Now I can wire things up and install..Then find some tunners for the neck and put it all together for a test flight..Then tear it all down and finish the body and neck..
I've got a Bigsby on it which was a bear to install..
Thanks for all the responces..
Old April 6th, 2012, 04:50 PM   #17 (permalink)
sjtalon's Avatar
and Deaf Eddie !
great news !
What pups do you have in there ?
Old April 6th, 2012, 06:30 PM   #18 (permalink)
Papa Joe's Avatar
and Deaf Eddie !
great news !
I don't know what they are..They were in my junk drawer..Doesn't really matter right now..I just want to get everything to fit together and make sure all is right before I start the finish...Don't even know yet what I'll use for a finish..Might leave it natural..
Name:	Bigsby Tele Build.jpg
Old April 7th, 2012, 03:58 PM   #19 (permalink)
Papa Joe's Avatar
Crazys thing..As usual my memory is in the crapper...While looking through some papers for something else, I found the diagram for a VM Squier Thinline..It's exactly the same switch..I drew it over a year ago..( Now if I could just find my other boot)...
Old April 7th, 2012, 04:54 PM   #20 (permalink)
sjtalon's Avatar
ROTFLMAO
Geetar looks SWEET by the way !
