Old February 27th, 2012, 05:42 PM   #1 (permalink)
snakestrecher$'s Avatar
How Do i get Sharpie off a guitar?
I have a 52 AVRI, any ideas on how to remove a sharpie autograph
snakestrecher$ is offline   Reply With Quote
Old February 27th, 2012, 05:50 PM   #2 (permalink)
Turtleface's Avatar
Rub it with a dry erase marker, then wipe clean.
Turtleface is offline   Reply With Quote
Old February 27th, 2012, 05:51 PM   #3 (permalink)
RonS's Avatar
I have a signature in one of my acoustics. I have thought about using a Mr. Clean magic sponge, but I am afraid to try it. You might want to test it on something else first.
RonS
RonS is offline   Reply With Quote
Old February 27th, 2012, 05:52 PM   #4 (permalink)
czook's Avatar
I've used naptha, but test an area. Lighter fluid.
czook is offline   Reply With Quote
Old February 27th, 2012, 05:56 PM   #5 (permalink)
TC6969's Avatar
WD-40
TC6969 is offline   Reply With Quote
Old February 27th, 2012, 05:58 PM   #6 (permalink)
thorton077's Avatar
The best sharpie remover i have found to be spray sun block. I discovered it a long time ago when I was at my brother's soccer camp to pick him up. His name was written in sharpie, and I picked it up right after putting sunblock on. I have used it on everything i needed to remove sharpie from since. Haven't tried it on a guitar though.
Thomas
"That's no reason to cry. One cries because one is sad. For example, I cry because others are stupid, and that makes me sad." -Sheldon
thorton077 is offline   Reply With Quote
Old February 27th, 2012, 06:53 PM   #7 (permalink)
I've removed sharpie from a car using acetone. Test anything you will be trying in a hidden place first (like a pickup cavity or something) to be sure it won't react.
LocustPlague is offline   Reply With Quote
Old February 27th, 2012, 07:07 PM   #8 (permalink)
WaylonFan76's Avatar
I have to ask: is it a Jack White autograph ???
"I don't hate people, I just feel better when they aren't around" Charles Bukowski
WaylonFan76 is offline   Reply With Quote
Old February 27th, 2012, 07:11 PM   #9 (permalink)
flyingbanana's Avatar
1. Mr. Clean Magic Eraser
2. WD-40
3. Anti-bacterial hand gel
4. Hairspray
5. Cooking spray
6. Edited for content...
7. Bleach (depending on the surface)
8. Goof Off
Even some gas on a rag would work. Smells good too.
PS. Don't you gas, bleach or alcohol on lacquer....although it does come to mind that I have used alcohol on lacquer....use at your own risk.
flyingbanana is offline   Reply With Quote
Old February 27th, 2012, 07:14 PM   #10 (permalink)
Colt W. Knight's Avatar
Acetone will strip the lacquer from his 52RI.
the now mandatory =====>
Old February 27th, 2012, 07:16 PM   #11 (permalink)
2. WD-40
4. Hairspray
5. Cooking spray
6. Nail polish remover
8. Goof Off
Nail polish remover is acetone, and it will also strip the lacquer on a 52 RI.
Avoid anything with alcohol or acetone on a lacquer finish.
You can also buff the sharpie off using automotive polishing compounds.
Old February 27th, 2012, 08:19 PM   #12 (permalink)
gitold's Avatar
Fenders Meguiars Swirl and Haze remover gets it of immediately and safely.
gitold is offline   Reply With Quote
Old February 27th, 2012, 08:28 PM   #13 (permalink)
paulvcarter's Avatar
"Yo Momma"
...joke....
Keep Calm, Ramble On
Band: www:theprudes.com
Gear: Danocaster Tele, Fender B bender tele, Brian May Super, Les Paul Custom, Atelier Z Stratocaster, Eric Clapton Strat, PRS CE24, Vox AC30, Fender Vibro Champ EC.
paulvcarter is offline   Reply With Quote
Old February 27th, 2012, 10:16 PM   #14 (permalink)
Guitar Rat's Avatar
A few months back, a ballpoint pen I use for chord chart notes exploded in my guitar case and the ink got all over the body and neck of my 52RI.
Based on recommendations of this board, I tried hairspray on it. A half hour of elbow grease and it was virtually all removed. Absolutely no damage to the finish (though my guitar smelled like a 15 year-old girl from 1987 for a few days).
So, hairspray is my vote. I know ballpoint is not the same as sharpie, but that would be my first line of attack.
Guitar Rat is offline   Reply With Quote
Old February 28th, 2012, 02:03 AM   #15 (permalink)
dwlb's Avatar
Don't use OOPS. It will drive the ink into the grain. Please don't ask how I know.
"I never practice my guitar. From time to time I just open the case and throw in a piece of raw meat." --Wes Montgomery
dwlb is offline   Reply With Quote
Old February 28th, 2012, 03:09 AM   #16 (permalink)
Thank you for correcting that. I copied and pasted from the internet. I know better, and updated my post. That was retarrrrrrded.
Old February 28th, 2012, 03:42 AM   #17 (permalink)
1955's Avatar
I gotta ask who signed it!
"Discipline is the bridge between goals and accomplishment." Jim Rohn
1955 is offline   Reply With Quote
Old February 28th, 2012, 09:25 AM   #18 (permalink)
Vizcaster's Avatar
Just keep in mind that that AVR has a nitrocellulose lacquer finish which is more delicate than other modern guitar finishes. Alcohol will harm it and will leave white marks; acetone will dissolve the finish completely. Naptha (lighter fluid) is safe, but it might have little effect on the sharpie. It really depends on how far into the lacquer the sharpie has burned itself.
Old February 28th, 2012, 12:29 PM   #19 (permalink)
gitlvr's Avatar
This is what i would use. Or any good swirl remover or buffing compound. Should take it right off, no problem.
Mike
The only thing necessary for evil to thrive is for good men to do nothing.
gitlvr is offline   Reply With Quote
Old February 28th, 2012, 12:37 PM   #20 (permalink)
I have used peanut butter, yes I said peanut butter, it works perfect to remove the residue from when you remove the clear protective plastic on pick guards.
ricksandteles is offline   Reply With Quote
