Old January 23rd, 2012, 08:57 AM   #1 (permalink)
elmicko's Avatar
Strat Pickup In a Tele???
Just a quick question. Can a strat size pickup be put in the neck position on a telecaster without removing wood? I know I'll need to alter the pickguard. Thanks!!
Maker of some finely crafted, twangy redneck noise...
http://www.reverbnation.com/goatwhiskey
elmicko is offline   Reply With Quote
Old January 23rd, 2012, 10:29 AM   #2 (permalink)
garrett's Avatar
Depends on what type of body.
--Garrett--
garrett is offline   Reply With Quote
Old January 23rd, 2012, 10:42 AM   #3 (permalink)
elmicko's Avatar
New MIM standard.
Old January 23rd, 2012, 12:56 PM   #4 (permalink)
garrett's Avatar
You should be good to go. It should be routed to accommodate a humbucker. Take the pick guard off and have a look to confirm, though, just in case.
--Garrett--
Old January 23rd, 2012, 01:03 PM   #5 (permalink)
SixShooter's Avatar
It won't fit in the pickguard if you are using a standard Tele one.
"Something entirely new in the electric Spanish guitar field..."
SixShooter is offline   Reply With Quote
Old January 23rd, 2012, 01:16 PM   #6 (permalink)
elmicko's Avatar
I knew I was going to have to replace the pickguard, but I want to get a black one anyway (the stock white one doesn't look very good on my guitar). I just didn't want to buy a pickguard and pickup if it wouldn't fit without routing.
Old January 23rd, 2012, 01:22 PM   #7 (permalink)
Dflo's Avatar
Gotta rout the pickgaurd, Sometimes not the body though, All my Teles have neck position strat pickups.
Dflo is offline   Reply With Quote
Old January 23rd, 2012, 01:51 PM   #8 (permalink)
jefrs's Avatar
It may fit if you take its cover off.
Me, I got tele pickups in a strat.
Old January 23rd, 2012, 02:11 PM   #9 (permalink)
Banned Troll
GFS Fatbody. Very Stratish sound. No need to route the pick guard. I have one in one of my Tele's and I really think it has a fabulous, clean tone to it.
http://www.guitarfetish.com/Alnico-F...ckup_p_76.html
dada is offline   Reply With Quote
Old January 23rd, 2012, 02:30 PM   #10 (permalink)
elmicko's Avatar
I like the price...do you leave them exposed or put the chrome cover on them?
Old January 23rd, 2012, 02:32 PM   #11 (permalink)
Banned Troll
They don't come with a cover, nor do I know if the standard neck cover fits. It looks badass with the huge pole pieces.
Old January 23rd, 2012, 03:28 PM   #12 (permalink)
elmicko's Avatar
I believe that just might be the one I choose. Thanks!
Old January 23rd, 2012, 03:48 PM   #13 (permalink)
elmicko's Avatar
OK, I just pulled the trigger on the Guitarfetish pickup. Thanks for all the help with this.
Old January 23rd, 2012, 05:17 PM   #14 (permalink)
Rob DiStefano's Avatar
an uncovered strat pup will fit a tele pickguard. that's a fave combo for me - the twang and growl of a good tele bridge pup and the bluez tone of a strat neck pup.
fretted instrument tech ~ custom partscasters
Cavalier Single Coil Pickups
Molon Labe - come and get them!
Rob DiStefano is online now   Reply With Quote
Old January 23rd, 2012, 10:29 PM   #15 (permalink)
SixShooter's Avatar
The mullet of pickup combos!
Old January 24th, 2012, 06:05 PM   #16 (permalink)
I actually just put an uncovered Strat pup in my tele neck position. No routing, no pickguard mods. Sounds AWESOME.
c.winn is online now   Reply With Quote
Old January 24th, 2012, 06:27 PM   #17 (permalink)
telepath's Avatar
Uncovered strat pup sounds great.
Choose one with a fairly high output , IME, as you may end up wanting it set relatively low.
Why? - well, otherwise the top e tends to snag itself under the 'lip' on the edge of the bobbin - if you dig in by any measure.
I had that problem with a GFS Fatbody neck pup also.
I had to wind it with tape (bicycle handlebar cloth tape is good) to reduce / negate the lip. (definitely worth the effort)
That said, a covered strat pickup will fit in the route of your MIM I believe.
They are usually 'bucker routed I'm sure.
Enlarging pickguard 'hole' is not a big job. Dremel and sandpaper wrapped around a dowel and 10 mins of your time ;)
telepath is offline   Reply With Quote
Old January 24th, 2012, 06:56 PM   #18 (permalink)
WaylonFan76's Avatar
Too bad you already pulled the trigger on the pup... Harmonic Design makes a Tele size Strat pup : Scroll to the bottom of the page http://harmonicdesign.net/allpages/teles.html
"I don't hate people, I just feel better when they aren't around" Charles Bukowski
WaylonFan76 is offline   Reply With Quote
Old January 28th, 2012, 08:37 PM   #19 (permalink)
elmicko's Avatar
Got the Guitar Fetish pickup installed today and dang it HONKS. Absolutely love it. Changed out the pickguard to a black one and did the Fezz Parka mod too. Very happy with the end result.
Old February 3rd, 2012, 09:44 PM   #20 (permalink)
Isn't that what Jerry Donahue does? Strat pickup in the neck, Tele in the bridge? Good combo... Not to my taste though, I'm afraid I'm with Roy Buchanan on this one... The Tele's neck pickup has a charm all of it's own.
paranoidsam is offline   Reply With Quote
