Mixing Fender and Duncan pups?
I currently own a Fender Lite Ash Tele. I'm looking to replace the neck pickup with the neck pickup from a USA Fender B-Bender (Nashville) Telecaster.
I figure even if the Nashville was setup to be hum cancelling in the 2 and 4 positions, that only the middle pup would be RW/RP. Therefore, the neck should be standard American tele winding/polarity. So would this Fender neck pup be readily compatible with the Duncan AlnicoII pro bridge pup?
"There's an edge to real rock 'n' roll. It's all that matters." - Neil Young |
Electronically, I see no reason why you can't mix the two brands. Tonally, I have no idea. If the two brands are wound backwards, you'd be able to get something resembling Strat quack in the middle position, I'd think. If they're wound the same, then you'd have a nice mixture of tones.
Mixing the brands isn't going to hurt the guitar or amp at all. |
I have a Duncan Little '59 in the bridge and my neck pickup was pulled from the neck of a Mexican Strat. They sound great together.
facebook.com/householdtales |
The neck polarity would be normal FENDER (north top polarization) but it's hard to say if it will be right phase wise (which has nothing to do with sounding like a strat) with the SD. So even though the Fender is "normal" doesn't mean it will be "normal" with another manufacture as there is no standard to polarization, or wind direction.
Just wire the neck up and hook the bridge up with jumper leads and play them combined. If they sound weak and thin (nasel-ly) then switch the bridge leads. The green and black would be the ones reversed from ground to switch or vise versa. |
#6 (permalink) | ||
Thanks. This gives me hope.
I read on the Duncan site that the worst case scenario is that you have to flip the magnets. Hope that isn't necessary.
#12 (permalink) | |
You're welcome.
Just another note. The manufactures wire colors are going to tell a person how to wire the pickup in regards to which lead goes were. As far as ONE pickup, it doesn't matter which way you wire it actually. Now when you wire two pickups in a guitar, each has to be connected correctly WIND WISE so together, they are in phase with each other. In the case of a set that is noise cancelling, one pickup is RW/RP of the other so when played together, they basically remove unwanted signal NOT produced by each pup. RW/RP is a relative term, so two different polarizations are a must for noise cancel, but the real way to describe it is REVERSE CONNECTED in lieu of reverse wound. So it just boils down to either the START of the wind going to ground, or the FINISH of the wind going to ground, and that is what determines which way the little electron Gommers run around the coil, cw or ccw, as current is generated. |
#14 (permalink) | |
Oh crap, I sit corrected. When I cut and pasted Duncan AlnicoII pro bridge to Google for images, a HB came up, so go by what mellecaster posted if you have to reverse the lead of one/either, as you have SINGLE COIL PUPS. But like I said, try one with test leads first, and then do the mod if you have to reverse it from what is standard for the leads. That is Fender has BLACK to ground white to switch. |
#16 (permalink) | |
decide to Mod the Bridge Pup, the added separate Ground to the Bridge plate is a good Idea anyway IMO. |
#19 (permalink) | |
Invaluable knowledge for newbies like myself.
#20 (permalink) |
Let us know how it works out. As far as checking the polarity of your set: Take a compass to the top of the pickup, the one the NORTH end of the needle points to is a SOUTH TOP polarization. You can also take the two you have and hold them top to top with each other, if they attract (stick together) that means they are opposites, and that's good, as then you will have noise cancel in position 2. |
