Old November 9th, 2011, 11:28 AM   #1 (permalink)
Willie&Waylon's Avatar
5-way switch wiring help needed
I'm building a "stealth" Esquire with a 5-way switch and vol & tone knobs have pull switches I'm not certain which wiring diagram to use. My bridge pickup is a BG1400/Pearly Gates, 2 pickups under the guard are strat single coil type. I'd like for the bridge to be tapped. Any help anyone could give is much appreciated. Thanks.
Sometimes nothin's a pretty cool hand...
Willie&Waylon is offline   Reply With Quote
Old November 9th, 2011, 11:42 AM   #2 (permalink)
Phostenix's Avatar
What do you want the 5 positions of the switch to be?
What do you want the push-pull switches to do?
Whatsoever your hand finds to do, do it with all your might. ~ King Solomon
My Guitar Wiring Library:
https://sites.google.com/site/phoste...gdiagrams/home
Phostenix is offline   Reply With Quote
Old November 12th, 2011, 09:07 AM   #3 (permalink)
Well, I've got a wiring diagram for it but it's for a typical 2-wire bridge...I'm not sure where to solder the other 2 wires of the bridge pickup. Should I scan a copy of the wiring diagram that came with the control plate?
Old November 12th, 2011, 10:50 AM   #4 (permalink)
Phostenix's Avatar
Once I know how you want it to switch, I can tell you how to wire up the bridge pickup.
You said you have 2 push-pull pots. I'm assuming that you want one of them to split the bridge humbucker. What do you want the other one to do?
Is your 5-way switch a standard Strat 5-way that you want to wire for standard Strat switching?
Old November 13th, 2011, 11:55 AM   #5 (permalink)
Yeah, I want to be able to split the bridge and then just have the others like a typical strat setup I guess. I bought it originally to use in a Nashville tele setup. Then I was going to do just an Esquire with a no load tone pot to do a "spin-a-split" setup with it. Then I thought I'd just do a stealth Esquire.
I definitely want to be able to split the bridge coils. What would my options be with the other push/pull pot?
Old November 13th, 2011, 07:09 PM   #6 (permalink)
Phostenix's Avatar
Here's a diagram of an HSS Strat with 1 volume, 1 tone & a push-pull to split the bridge pickup:
http://www.seymourduncan.com/support...2s_1v_1t_5w_pp
