Tone similar to Strat Quack on a Tele?
I have a need to get a tone similar to the "quack" pickup position on a Strat. Is there a way to get something like that on a Tele? I have a 4-position switch and think that the combination pickup position in serial mode would be the closest, but maybe you can get something similar with just the bridge pickup? I am trying to get a funky tone for a particular song and that "quack" Strat position seems like what they used on the song.
The closest you will probably get is what is typically called Half Out-of-Phase or HOoP. The pickups are in parallel, but out-of-phase with a cap in series with the neck pickup. Adding a resistor with the cap on the neck pup & also adding a resistor in series with the bridge pup gets a little more quack.
Here's a drawing of a 5-way Tele with that setup:
Whatsoever your hand finds to do, do it with all your might. ~ King Solomon My Guitar Wiring Library: https://sites.google.com/site/phoste...gdiagrams/home |
+1 on what Phostenix said. He has a knack of figuring out just about any wiring you could desire. I'm thinking of even giving him a tricky strat wiring to figure out if he can
Did you change that diagramm? I remember looking at it once before, and I don't recall any resistors. What do they do? The baja comes with a half out of phase sound, but without resistors, so my curiosity is piqued! |
The Baja does indeed come with the cap in series with the neck pickup in the parallel out of phase position.
But the cap doesn't bring much to the party as I found when I replaced the S-1 (4p2w) with a push-pull (because I wanted a nice smooth linear vol pot). Do note that the strat selector shown above is a 4p Super-Switch(?), you cannot insert the cap with a 2p2w p-p switch. So then the easiest way to try-out is simply to flip the polarity of your existing neck pickup, it will need 3-wire conversion - cut the cold to case jumper and add a new case/shield ground wire - do not attempt to solder on the coil connections (it is a genuine and authentic pita visit your proctologist to resolder coil wires even for me, and I /can/ solder aluminium to stainless steel or glass)
#7 (permalink) | |
Whatsoever your hand finds to do, do it with all your might. ~ King Solomon My Guitar Wiring Library: https://sites.google.com/site/phoste...gdiagrams/home Last edited by Phostenix; November 8th, 2011 at 12:24 PM. |
I've been spending my free time the last couple of weeks working on a website to use as a library for my drawings. I have a lot more work to do on it, but the drawings that I wanted to post are all there. I still need to add descriptions to a lot of them.
I plan to keep adding to the site over time & add video demos, too. Feel free to check it out, but be aware that it's not quite ready for prime time. https://sites.google.com/site/phostenixwiringdiagrams/
#9 (permalink) | |
Very cool stuff. Thanks for posting the link . . . |
#10 (permalink) | |
Oh ya that's right, it's a cap on the S1. Some guys will put a resitor on a Tele bridge pup to take some of the ice pick out, that's why my head was on resistors, as well as Phostenix. |
#11 (permalink) | |
Bob "You've got a hole in your soul if you don't dig the Blues" |
#12 (permalink) | |
It looks very interesting.
#15 (permalink) | |
I guess I could add that... How's this?
#16 (permalink) | |
#18 (permalink) |
My brain is having trouble with 1/2 out of phase. So is this one coil reverse polarity while out of phase with the other coil ?
A Twin always will cut it... but I don't recommend it for everybody. It's like a big dog, you have to take responsibility for it. Not to mention... be prepared to lift it. BTW, how $good$ a guitar is, is no indicator of how badly it can be played! |
#19 (permalink) | |
Now, if we attach a capacitor to one of the pickups to cut away a chunk of its signal, the pickups become even more "different" and less signal gets cancelled out, making for a more useful sound than pure out of phase. P: Cool website BTW! |
#20 (permalink) | |
Ya, that's why I put a question mark after that in my 1st post. Half oop I don't think electrically (reality) there would be such a thing with a set of pickups, I'm thinking it's just a tone term, meaning the sound is not really like REAL oop which sounds like crap. So with either some cap or resistor wizardry, that change in tone of one of the pups in the set does the deal......or makes it a tone someone would want. Like on the Baja Tele, they put a .01µF cap on the neck pup S1 point. Is that the deal ?? |
