Old October 11th, 2011, 06:38 AM   #1 (permalink)
Squier Make Over: Tele Bridge to fit over humbucker hole.
Hi! Got an Obey Squier that i would want to convert to a classic tele Setup.
From this:
to This:
My Main problem is the cut for the humbucker on the bridge pickup may not be covered by your standard tele bridge.
Got any suggestions where to find a tele bridge that is more than or equal to 86mm wide so as to cover up the humbucker routs?
TIA!
stratzkiboy is offline   Reply With Quote
Old October 11th, 2011, 06:51 AM   #2 (permalink)
GigsbyBoyUK's Avatar
I doubt it. A standard Tele bridge made for a single coil will never cover that gap. You could get a Tele bridge made for a humbucker and go for a humbucker-sized-P90 instead. Maybe try a pickup like that first using the existing pickup ring to see how it sounds?
Alternatively, you are into various options such as making a pickguard to cover the gaps. Usually you would fill the gaps with little wooden blocks and filler at the side of the bridge and re-finish the area but that won't be possible due to your guitar's complicated graphics.
FWIW I would leave it as it is and have fun saving for a second Tele with more traditional looks and pickups.
GigsbyBoyUK is offline   Reply With Quote
