Old September 20th, 2011, 03:38 PM   #1 (permalink)
metalicaster's Avatar
How much neck angle on an LP junior?
Doing a tele/LP hybrid build
Using TOM bridge and Bigsby with Les Paul hardware on a tele body
The junior is a flat top too so I would think the numbers are roughly transferable, Approximately what angle is the neck set at on a Les Paul Junior please?
"Light beer is for people who like having a hangover without having the fun first."
metalicaster is offline   Reply With Quote
Old September 20th, 2011, 04:19 PM   #2 (permalink)
Formerly known as Eryque
KokoTele's Avatar
It's 3 degrees, give or take.
I think your best option here is to make an accurate full-size drawing with the hardware you want and take measurements. That's the only way you'll be certain to get it right on your build.
Parts & Pickups
www.kokoteleguitarworks.com
Old September 20th, 2011, 04:30 PM   #3 (permalink)
Gonna do that when I get all the hardware measured up.
I just needed an estimate to see whether I'd be better off having my buddy route the cavity with his better machines if it's too extreme an angle, but 3 degrees would be achievable in my workshop no problems.
Old September 20th, 2011, 11:02 PM   #4 (permalink)
mellecaster's Avatar
Don't mean to Hijack this thread....but Eric, I've been workin on a bunch of
Nashville Made Gibson Les Pauls as of late, and noticed on many of them you
have to really crank up the Bridge & Tailpiece to even get 4/64" Action on the Low E
Have you been running into this ?...Could they be gettin their angle wrong ?
Old September 21st, 2011, 12:03 AM   #5 (permalink)
KokoTele's Avatar
I have seen this, but it hasn't been consistent. Then again, I don't do the volume you do.
The Les Paul tenon is supposed to be curved on the bottom so the angle can be changed a little with only minor tweaking when they install it. I wonder if they have a new person on the line who doesn't know how to work the jig quite right or something.
Parts & Pickups
Old September 21st, 2011, 02:46 AM   #6 (permalink)
I'm not after an exact Les Paul replica, just roughly how much angle I would need for a TOM bridge etc. Since I'm making the body from scratch I'd sooner angle the pocket than use shims.
btw I've ran my measurements through a few formulas now and got 3-3.5 degrees
Old September 21st, 2011, 08:28 AM   #7 (permalink)
KokoTele's Avatar
Did you get that for the angle of the fretboard, or for the strings?
Parts & Pickups
Old September 21st, 2011, 03:27 PM   #8 (permalink)
That would be for the fret board,
with a flat top, 25.5" scale and .9" high bridge and the other few necessary measurements it comes to 3.7 degrees neck tilt
http://www.tundraman.com/Guitars/NeckAngle/index.php
I used this site to check and found the same
I left room to raise the bridge up a bit to get a proper break angle from a bar-less Bigsby so the bridge is higher than it normally would be.
Old September 21st, 2011, 06:22 PM   #9 (permalink)
It varied. Typically, a 55 Junior has a shallower neck angle than a 57. Typically, a 57 Junior has a shallower neck angle than a 59.
slack is offline   Reply With Quote
