String buzz
I just finished building my first tele and noticed that I get string buzz. I have raised the saddles and nut, adjusted the truss rod, and level sanded and lowered my frets. The buzz seems to be coming from the bottom of the neck. the only thing I can think to do is make the neck pocket deeper or sand a little off the heel of the neck. Any suggestions?
Might be ski jump: The neck in the area of the heel is suddenly stiffer, so it has less curvature resulting in the frets being as if they were higher closere to the body.
I hope someone has a better cure than hand work these frets. Welcome, closer to Waco, or College Station? (if that's not a political question)
Schnapsidee |
#9 (permalink) | |
![]() Formerly known as Eryque Doctor of Teleocity
Relief is the amount of bend in the neck. You measure by fretting the first and last frets and measuring the gap between the string and the 8th fret. Since you're new at this and probably don't have a feel for what it should look like, use a set of feeler gauges. You're shooting for between .005 and .010". Too much gap, tighten the truss rod 1/4 turn. Too little, loosen it. (I'm guessing that you have a little bit of back bow, so you'll need to loosen it.)
Use this link for info on how to check if your nut slots are too low (or too high): http://frets.com/FRETSPages/Musician...nutaction.html |
