1 Humbucker and 4 Way Switch - Possible?
Hi,
I have a Tele with one humbucker (4 wire) in the bridge. I would like to know if it would be possible to put a 4 way switch in and do some sort of cool wiring trick. Maybe a split/parallel/series thing or something? Any ideas? |
Ive done a 5 way switch with 2 single coil sized humbuckers so it had humbucker sound but was also coil tapped for the classic tele sound. Pretty cool sounds. What you could do is use a 4 way and have the pickup in series,then parallel,then coil one tapped and then the second coil tapped. I also know the avril lavine tele runs one humbucker with a 3 way so it has normal humbucking mode then has each coil tapped.
Here's my untested drawing. I used Seymour Duncan colors.
Whatsoever your hand finds to do, do it with all your might. ~ King Solomon My Guitar Wiring Library: https://sites.google.com/site/phoste...gdiagrams/home |
I was thinking the same thing, as I am planning for my first build. I was thinking something along the lines of this:
http://www.seymourduncan.com/support...tic=esquire_hb But I am not entirely sure how this would work. What did you use? Sorry for posting so long after, but I could do with some inspiration |
