Old August 3rd, 2011, 03:37 PM   #1 (permalink)
Tele Blacktop HH Loose Neck Pickup
MY Tele Blacktop HH has Loose Neck Pickup. You can wiggle it up and down when you try. Just seeing if thats normal?
crocwhat is offline   Reply With Quote
Old August 3rd, 2011, 04:01 PM   #2 (permalink)
comebackkid's Avatar
Thats probably the mounting screw gone loose from the plate the pickup is attached to - you'd have to remove the pickguard and remount the screw thru the pickguard and back into the pup-plate.
Ow and did I mention that's a hellish job unless you want to remove your strings? ;)
comebackkid is offline   Reply With Quote
Old August 3rd, 2011, 04:12 PM   #3 (permalink)
Dang that sucks! I bought this thing like last month from guitar center.
Old August 3rd, 2011, 04:26 PM   #4 (permalink)
Bartholomew3's Avatar
Every humbucker I've had moves to some degree.
Bartholomew3 is offline   Reply With Quote
Old August 3rd, 2011, 06:15 PM   #5 (permalink)
mellecaster's Avatar
Yep...on a Bucker some wiggle is normal.
Old August 3rd, 2011, 06:27 PM   #6 (permalink)
dsutton24's Avatar
They will move some. Put your finger on the pickup near the adjusting screws an push down. If the pickup disappears into the body then the screw has just come out of the mounting ear. Just dismount the pickguard, locate the missing spring, and reassemble everything.
Most likely the pickup is still attaced to the screw, in fact when you push down or wiggle the pickup you'll see the screw head move along with it, or the pickguard flexing slightly. If so, everything is fine. Just play it and forget it.
Yet another hobby that is completely out of control...
dsutton24 is offline   Reply With Quote
Old August 4th, 2011, 01:25 PM   #7 (permalink)
Hahaha thanks guys. Pretty sure it's okay. Just overlooking things way too much. My first fender I ever had though. Love this thing!
