Old August 1st, 2011, 11:13 AM   #1 (permalink)
Out of phase pickup question
Hi,
I pulled my 71 Tele out of the closet after 20 years.
The bridge pickup had been a little weak.
I pulled the pickups and they were both Duncans.
(I remember Duncans are wound backward)
I re-used the neck pickup as it sounds great.
My new bridge pickup needless to say is out of phase in the middle position.
OK.
Specifically:
I have been told to simply reverse the neck pup leads.
This works just fine, but if I touch the pole pieces, it hums like a big dog.
I tried to work around it, but for some reason, sweat, whatever..... I always make contact with the pole pieces while playing live.
BUZZZZZZZ!
I read Duncan's wiring diagrams for reversing phase on the bridge pup.
It is not a Duncan pup, but has the exact same ground scheme.
I understand cutting the baseplate ground and reversing the bridge leads.
If I do this, will I get the same BUZZZZ! when I touch the bridge polepieces?
I just want to ask before I am disappointed and wreck the new pickup somehow anyway.
Thanks for your time with this.
ralph phillips is offline   Reply With Quote
Old August 1st, 2011, 11:22 AM   #2 (permalink)
Formerly known as Eryque
KokoTele's Avatar
Snip that baseplate ground, and then run a new ground wire just for the baseplate.
Parts & Pickups
www.kokoteleguitarworks.com
Old August 1st, 2011, 12:35 PM   #3 (permalink)
mellecaster's Avatar
If others may be wondering what you mean ?...Like This :
