Schaller Megaswitch Model E Wiring - Switching - Telecaster Guitar Forum
Old August 1st, 2011, 10:35 AM   #1 (permalink)
Phostenix's Avatar
Here's some info on how the Schaller Megaswitch Model E 5-way switch works:
Terminals:
1. Connected to Terminal 3 in positions 2 & 4
2. Connected to Terminal 3 in positions 3, 4, & 5
3. Normally connected to the Output
4. Normally connected to Ground
5. Connected to Terminal 4 in positions 3 & 4
6. Connected to Terminal 3 in positions 3 and to Terminal 4 in position 2
7. Connected to Terminal 3 in positions 1 & 2
Switching Arrangement (Terminal Connections):
1 is normally the Middle pup Hot lead
2 is normally the Neck pup Hot lead
3 is Normally Output
4 is normally Ground, except with 3 single coils (not connected)
6 is normally the coil splits of a Bridge humbucker
5 is normally the coil splits of a Neck humbucker
7 is normally the Bridge pup Hot lead
Switching Positions:
1. 7 to 3
2. 7 to 3, 1 to 3, 6 to 4
3. 6 to 3, 2 to 3, 5 to 4
4. 2 to 3, 1 to 3, 5 to 4
5. 2 to 3
http://www.eyb-guitars.de/Eyb-Englis...switch%20E.pdf
Whatsoever your hand finds to do, do it with all your might. ~ King Solomon
My Guitar Wiring Library:
https://sites.google.com/site/phoste...gdiagrams/home
Phostenix is offline   Reply With Quote
Old November 23rd, 2012, 09:23 PM   #2 (permalink)
Hi Phostenix
Long time lurker / first question here.
I bought the E Megaswitch thinking it was like a Super Switch but alas not so.
I am currently using a Fender Super Switch for the following config.
Pos:
1) Bridge with Tone (last knob = T2)
2) Br + Mid with tone (T2)
3) Mid (no tone pot...just a treble bleed resistor)
4) M + N with tone (first tone knob = T1)
5) N with tone (T1)
I really like this setup (the mid pup by itself is really cool with the Bill Lawerence microcoils I am using) but the switch is pretty poor quality (I.E. in Pos 3, you can get pos 2 without even clicking out of pos 3). It's really loose and easy to get the wrong selection while playing.
Question: Is it possible to get the same config with the E Mega? I could cut a trace etc. if I had to? or should I find another switch?
I really like the feel of the Mega...
Thanks and Best
F5
fleximan5 is offline   Reply With Quote
Old November 26th, 2012, 08:54 PM   #3 (permalink)
Phostenix's Avatar
It looks like you could do what you want with a standard 5-way switch. Connect Tone 1 directly to the neck pickup & Tone 2 directly to the bridge pickup and you'd have no tone pot in the middle position.
Sponsored Links   #
Old January 3rd, 2014, 03:00 PM   #4 (permalink)
What is the difference between the E Megaswitch and a CRL 5-way Lever Switch http://www.stewmac.com/shop/Electron...er_Switch.html
Gregmw is offline   Reply With Quote
» Random Photo for Guests
79 Siennaburst Stratóbeat w/lots of autographs
» Recent ThreadsGuests
Fender Logan Custom Guitars
