Brass screws for bolt on neck
I'm in the middle of a build that uses gold hardware and I want to know if brass screws are strong enough to bolt on a neck. Normally I like to use stainless steel but I need a gold appearance and polished brass looks really nice. However I don't want any broken screws.
Well, not an easy question, as it turns out.
Best I could find were torque specs for 8-32 machine screws. The chart lists 17.8 lb/ft for carbon steel screws, and 16.2 lb/ft for brass, a difference of 9.8%. That doesn't relate directly to the tensile strngth of brass vs. steel, but it's interesting nonetheless. If I was to guess, I think brass would be fine on an instrument that lead a pampered life, and wasn't knocked around a lot or strung with 14s. Maybe.
Yet another hobby that is completely out of control... |
#4 (permalink) | |
Brass would likely be fine, the grades of brass used in screws have tensile strength that's not greatly less than the mild steel common screws are made of, but it is a much softer metal and thus would be more likely to have its threads strip; Use of threaded inserts in neck recommended.
Other options include plated steels, some of these have a goldish color. Many people use nail polish to paint the heads of allen screws. When in doubt, check McFeelys or McMaster-Carr websites: these are goldmines of information on mechanical stuff. And great sources for hardware and fabrication stock. http://www.mcfeelys.com/tech/materials.htm
Schnapsidee |
#13 (permalink) | |
#14 (permalink) | |
#16 (permalink) |
![]() Poster Extraordinaire
s/s neck screws only, for me. brass is far too soft, imo.
![]() fretted instrument tech ~ custom partscasters Cavalier Single Coil Pickups Molon Labe - come and get them! |
#17 (permalink) |
![]() Friend of Leo's
I would buy
I would buy the common gold (color) plated steel neck screws from any of the numerous sources and simply cut them to the length you need. Easily done with a hack saw or Dremel cut-off disk. The screw point is easily done with a common file and a few strokes.
Rob
"If I won the lotto... I would be a full time Luthier until the money ran out". Coffee, Sand Paper & Lacquer Fumes..... now thats a good day! www.rhomcoguitars.com |
#19 (permalink) | |
