Old January 25th, 2005, 10:00 AM   #1 (permalink)
Anyone sand / steel wool the back 'O the neck?
Just wondering. Im thinking of maybe doing one or the other to make the finish a little less slick...my thoughts are to first try the steel wool....make it more of a matte finish.
MANX is offline   Reply With Quote
Old January 25th, 2005, 10:51 AM   #2 (permalink)
Fret Wilkes's Avatar
Scotchbrite pads
Folks here turned me onto the 3M Scotchbrite abrasive pads. They were designed for doing dishes and can be found in the supermarket.
They come in different grade of abrasive and work great..no steel hairs from steel wool.
Go easy though, they work fast!
Fret
See, I didn't reconize ya when ya first drove up till ya stuck yer hand out and wove then I seen right off who ya was and knowd ya.
Fret Wilkes is offline   Reply With Quote
Old January 25th, 2005, 12:30 PM   #3 (permalink)
Mark Davis's Avatar
3M scotchbrite pads or 400-600 grit black sandpaper are the best. Steel wool fragments can get inside your pickups and possibly short them out.
Old January 25th, 2005, 01:25 PM   #4 (permalink)
Raymond's Avatar
I hate when a shiny finish "sucks" my hand to the neck. I've used 600-grit or 800-grit sand paper. You can use it either dry or wet, though I prefer dry to "see" what's going on. You should only sand until all the shine is gone. Be very careful. Also, superfine steel wool would work but to me cleaning up all the steel residue is a royal pain in the neck (I don't have a place to work so I use the kitchen…). I've use a big speaker magnet to try to get most the stuff, but still….
"That's a hard pill to swallow, buddy; when you find out what the blues is all about"
Raymond is offline   Reply With Quote
Old January 25th, 2005, 02:05 PM   #5 (permalink)
Lyle Caldwell's Avatar
+1 on the Scotchbrite. Go very easy. No pressure required. You can always take off more finish, but you can't put it back on.
"Everybody sings about Memphis, but nobody ever does anything about it."
Lyle Caldwell is offline   Reply With Quote
Old January 26th, 2005, 08:54 AM   #6 (permalink)
UGhhhh
Thanks for the replies guys, the scotchbrite seems great....but man I look at that finish and almost feel guilty thinking about taking it off!!! But I prefer to play a matte finish much better....so looks or feel? hahah decisions, decisions.
Old January 26th, 2005, 06:00 PM   #7 (permalink)
e-merlin's Avatar
I use 0000 steel wool, but I take the neck off before I do it to keep the steel wool dust out of the pickups. I'll probably switch to Scotchbrite one of these days.
'tone is in the underpants'
Old February 18th, 2005, 02:16 PM   #8 (permalink)
Over the years I've built a number of fiddles. The best thing I've found to remove glare and smooth out the finish is pumice. It's probably available at WalMart. If not, try your hardware store. It take a while longer to do things this way, but the extra time involved almost assures that you won't remove too much finish. Used wet (I mix a very small amount of Fiddlebrite cleaner with the pumice.) the stuff is like #gazillion sandpaper.
gopop is offline   Reply With Quote
Old February 18th, 2005, 08:35 PM   #9 (permalink)
My wife gets...
....those yellow sponges with the green scrubby stuff on the top. These work great dry for poly or nitro. I actually did the whole body, followed by Dupont #7, on my '63 RI Tele for a nice Closet Classic finish.
Jimbo
FrankFoxBand is offline   Reply With Quote
Old February 21st, 2005, 02:06 PM   #10 (permalink)
Guys......you can use steel wool with the neck on......just put some masking tape over the pups and seal them off real good. I do it all the time.
Can't play too hot, but my stuff looks good!
steve s is offline   Reply With Quote
Old February 23rd, 2005, 03:50 PM   #11 (permalink)
Vince a's Avatar
Ditto the "0000" steel wool and removing the neck!
Vince a is offline   Reply With Quote
