3-Way switch wiring help - Telecaster Guitar Forum
Old February 25th, 2011, 03:29 PM   #1 (permalink)
I just bought this switch to replace the broken one in my Tele, but i cant figure out the wiring. I cant seem to find anything that corresponds to this switch on google, and i know you guys on this fourm know what you're on about. Any help would be greatly appreciated, wether its a wiring diagram, or somewhere where i can get a clue as to what im dealing with
Lugs 2-3 are joined, 4-5 are joined, and 6-7 are joined.
ID:	74429   Click image for larger version
ID:	74430   Click image for larger version
Jonesy11 is offline   Reply With Quote
Old February 25th, 2011, 05:06 PM   #2 (permalink)
Thighbanez's Avatar
whoa...thats different.
Who is the manufacturer of that switch?
Thighbanez is offline   Reply With Quote
Old February 25th, 2011, 05:30 PM   #3 (permalink)
Do you have an ohmmeter? How many positions ?
Teleterr is offline   Reply With Quote
Sponsored Links   #
Old February 25th, 2011, 05:32 PM   #4 (permalink)
8 is in shadow?
Old February 25th, 2011, 05:44 PM   #5 (permalink)
sjtalon's Avatar
You could check yours against this with a ohm meter (continuity)
The "commons" are always connected to one of the other terminals and are usually jumped together and then a wire attached to go to the vol. pot.
http://www.seymourduncan.com/support...=standard_tele
Old February 25th, 2011, 06:27 PM   #6 (permalink)
Verne Bunsen's Avatar
Well, if it didn't come with a diagram, we'll figure one out. Grab your multimeter and do this:
1) Put the switch in whatever you want to call position "1" and test for continuity between all points. My guess is you'll find that either 2/3 OR 6/7 will have continuity with 1 AND/OR 8.
2) Put the switch in the middle position ("2") and test for continuity everywhere. I predict that 4/5 has continuity with 2/3 AND 6/7, along with 1 AND/OR 8.
3) Put the switch in position "3" and test for continuity everywhere. I'd expect that 2/3 OR 6/7 (whichever was not active in step 1) will now have continuity with 1 AND/OR 8.
Now, if my guesses were correct, we know how to wire it. Depending on how you orient the switch (PCB towards or away from pickups), you'll run the hot wire from your neck pickup to whichever lugs were active in the proper switch position, and likewise for the bridge. No extra wiring necessary for the middle position because PCB switches are slick like that. 1 AND/OR 8 will be your hot to the volume pot.
Or if I'm way off, we can still figure out what goes where by knowing what has continuity with what when the switch is in a given position. Post what the ohmmeter told you and we'll figure it out from there.
Hope that helps!!
Yeah, well, you know, that's just, like, your opinion, man...
Verne Bunsen is offline   Reply With Quote
Old February 26th, 2011, 04:25 AM   #7 (permalink)
Thanks everyone. It's a generic 3 way switch off eBay. Didn't mention a make or model. In hindsight I shouldve probably pain an extra 4 quid and got a fender :)
Old February 26th, 2011, 01:53 PM   #8 (permalink)
Thinlineggman's Avatar
Squires come with switches like that. I just gave up and used 2 volumes on my latest build since I couldn't figure out the stupid thing, and I'm too cheap to buy one that corresponds to a wiring diagram:P
Besides, I always have the tone on 10 so I don't personally need the tone knob anyways.
Thinlineggman is offline   Reply With Quote
Old February 26th, 2011, 03:01 PM   #9 (permalink)
sjtalon's Avatar
Squire:
» Random Photo for Guests
Jul_68_Tele_17
» Recent ThreadsGuests
NGD
Fender Logan Custom Guitars
