Old February 21st, 2011, 03:45 PM   #1 (permalink)
Amishius's Avatar
How Are Older Neck Pickups Mounted?
Hi all-
I'm sure this is covered, but I'd rather ask because I'm really enjoying the forum and got a lot of wonderful feedback after my last question:
How are older neck pickups mounted? In my soon to be owned MIM, there are two screw holes for the neck pickup, but how are older style pickups mounted?
Are there advantages to the new style or old style?
The reason I ask is because I'm curious if I can change my pickguard to an old style and mount the same pickups. What new hardware would be required?
Thanks in advance!
Amishius is offline   Reply With Quote
Old February 21st, 2011, 04:10 PM   #2 (permalink)
Suicideking's Avatar
Instead of mounting the pickups to the plastic pickguard like your new Tele with the 2 holes on either side of the neck pickup. The older 5 hole pickguard Teles mount the neck pickups straight into the bottom of the pickup cavity wood. The advantages are all specific to peoples own ears some say none some say it makes the world of difference mounting it to the wood. I would say try it yourself and see what you like..
Suicideking is offline   Reply With Quote
Old February 21st, 2011, 04:36 PM   #3 (permalink)
Amishius's Avatar
That sounds like a lot of work- or maybe just drilling. I'm a little scared to drill~
Old February 21st, 2011, 04:44 PM   #4 (permalink)
leftiecaster's Avatar
Originally Posted by Suicideking View Post
Instead of mounting the pickups to the plastic pickguard.......with the 2 holes on either side of the neck pickup. The older 5 hole pickguard Teles mount the neck pickups straight into the bottom of the pickup cavity wood...
If that had change occured in the 70's, would it have been refered to as a 'CBS cost-cutting' measure?
leftiecaster is offline   Reply With Quote
Old February 21st, 2011, 04:57 PM   #5 (permalink)
I am not sure exactly when the change came, but I know there are some new RI's that come with the neck pu mounted to the body. I dont think u would have to drill out a hole in your Tele, someone who knows more may correct me if I am wrong here, but you could prob just start a lil pilot then use wood screws the rest of the way..
Old February 21st, 2011, 04:59 PM   #6 (permalink)
Bolide's Avatar
+ Easy to swap out pickguards: Have a different pickguard for all the many wonders that are you.
- Slightly more difficult to spot for drilling,
=/= Sound path through just the body versus body+pickguard: You pick-em, likely not enough difference to detect.
Bolide is offline   Reply With Quote
Old February 21st, 2011, 07:42 PM   #7 (permalink)
What could be the reason Fender made this change with some of their Teles?
Old February 21st, 2011, 07:55 PM   #8 (permalink)
Amishius's Avatar
If I had to venture a guess, maybe in a more factory-oriented era, it's easier to just drop a pickguard and bridge with a pickup already installed? I dunno.
Old February 21st, 2011, 11:15 PM   #9 (permalink)
Yes,...and if that had happened during the CBS years,..the '70's bashers' would be highlighting it as another 'cost cutting' measure.
Yet,...it's,... "well it makes no difference either way".
Old February 21st, 2011, 11:25 PM   #10 (permalink)
Nice being able to tinker with pickup height without pulling the guard.
MickM is offline   Reply With Quote
Old February 22nd, 2011, 12:19 AM   #11 (permalink)
Amishius's Avatar
I don't know this whole CBS debate, so I won't pretend to know what's going on, but I can only assume there is some kind of practical answer, like MickM's. I assume it's easier to just grab your screw driver. Maybe it was a cost cutting thing AND an ease thing? Is the new bridge cheaper than the vintage, or is that an ease thing? Who knows? CBS? Cost-cutting? I'd love to hear some examples.
Old February 22nd, 2011, 01:16 AM   #12 (permalink)
True that.
IMO it's a cleaner look to eliminate those screw heads by the pickup. For me it's worth the hassle. Converting to body mount isn't too tough if you are good at layout and can control your drill depth.
Dim lights, thick smoke, and loud, loud music.
It's the only kind of life you'll ever understand.
You'll never make a wife to a home lovin' man.
Ricky D. is offline   Reply With Quote
Old February 22nd, 2011, 10:52 AM   #13 (permalink)
mellecaster's Avatar
Drill Baby...Drill....
Old February 22nd, 2011, 11:06 AM   #14 (permalink)
I like the cleaner look.
allen st. john is offline   Reply With Quote
Old February 22nd, 2011, 11:53 AM   #15 (permalink)
Bolide's Avatar
d'Oh!!!!!
Missed that decidedly positive aspect.
Gracias.
Old February 22nd, 2011, 06:32 PM   #16 (permalink)
This bugged me for ages. As previously mentioned, the pickup is screwed directly into the wood. Not sure how you line it up with the pickguard properly on the first pass.
For this reason I'm going to go for suspended pickup on my tele build. I'm also using a Strat neck pickup, so I'm already off some folks' Christmas Card lists!
Manolete is offline   Reply With Quote
Old February 22nd, 2011, 07:33 PM   #17 (permalink)
Amishius's Avatar
Meh- to each his own. Yeah, I'm not sure I want to mess with the wood too much- I might just live with it suspended. How often am I going to be looking at it while playing anyways, right?
Old February 24th, 2011, 05:28 PM   #18 (permalink)
Vizcaster's Avatar
As usual TDowns has the answer on how to locate a body-mounted pickup:
http://www.tdpri.com/forum/tele-home...ck-pickup.html
I'd also point out that guitarpartsresource has the thin number four screws that you'd need - they'll fit where the no. 6 machine screws would go into the fiber or plastic bobbin base for pickguard mounting.
Old February 25th, 2011, 05:05 AM   #19 (permalink)
varakeef's Avatar
The height adjusting of neck pup was relatively easy until 22 fret necks with overhang over the guard arrived. I think the height adjustement screws thru the guard was a solution to that.
http://www.youtube.com/watch?v=HHWkZZRLDHY
If you remove the noisy stuff inside the piano it makes a great house for a dog.
varakeef is offline   Reply With Quote
