Old February 18th, 2011, 01:58 PM   #1 (permalink)
TeleJedi's Avatar
tele necks from strat necks
Got this crazy little idea.....
Since a strat neck has a larger headstock, it can be cut into tele shape.
As for the heel, teles have squared heel and strats have slightly rounded heel.
If I shave the strat heel into tele shape, will it fit a tele body nicely with almost no gaps?
"G.A.S is incurable but parts-casters can control it....."
Custom Esquire: USACG, Rutters, Callaham, DonMare, DIY Tru-Oil Finish
TeleJedi is offline   Reply With Quote
Old February 18th, 2011, 02:01 PM   #2 (permalink)
Formerly known as Eryque
KokoTele's Avatar
Nope. The end of the Strat's heel is already at the same place as the end of the Tele's heel, so there are going to be gaps in the corners even if you don't square off the heel.
Why? Do you have a bag full of extra Strat necks or something? ;-)
Parts & Pickups
www.kokoteleguitarworks.com
Old February 18th, 2011, 02:06 PM   #3 (permalink)
TeleJedi's Avatar
I feel like giving up my strat, selling all the parts but I can't bear to sell my usacg neck.
Old February 18th, 2011, 02:18 PM   #4 (permalink)
BigDaddyLH's Avatar
Make a Blind Faith tribute Tele!
“The problem with the world is that the intelligent people are full of doubts, while the stupid ones are full of confidence.” -- Charles Bukowski
Old February 18th, 2011, 02:21 PM   #5 (permalink)
TeleJedi's Avatar
Blind faith tele.....
I wonder how some people put strat necks on tele bodies. The heel is different which also means that the pickguard might not fit properly.
Old February 18th, 2011, 02:27 PM   #6 (permalink)
mellecaster's Avatar
Uhhh...you make a New Pickguard that does fit properly...Not exactly Rocket Science, it's a piece of thin Plastic.
Old February 18th, 2011, 02:35 PM   #7 (permalink)
TeleJedi's Avatar
I get it..... I don't modify the strat neck, I just need a slightly modified pickguard and a slightly modified neck pocket on the tele body.
Old February 18th, 2011, 02:39 PM   #8 (permalink)
shouldn't need to modify the neck pocket at all. just need a new pickguard to match the heel shape. unless the strat neck has a 22nd fret, then it covers the gaps to a degree that may or may not be enough for you. may not even need a new pickguard.
exhausted is offline   Reply With Quote
Old February 18th, 2011, 02:53 PM   #9 (permalink)
I wouldn't say you modify either the body OR the guard. If you have a tele body + tele pickguard + strat neck, to get the neck to work, you can use a few approaches.
1) Leave the body as is. When you bolt on the neck, there will be gaps on the corners. Get a new tele pickguard with strat-style heel. No amount of "modification will put that plastic back into the corners.
2) Fill the neck pocket of the tele body and re-route for strat-style neck heel. Get a new tele pickguard with strat heel.
3) Get a new body with a strat heel. Get a new pickguard with a strat heel.
LocustPlague is offline   Reply With Quote
Old February 18th, 2011, 03:12 PM   #10 (permalink)
black_doug's Avatar
Live Blind Faith
Unless you're in a Spirit-filled church, you ain't in no church at all.
- Bob Dylan
www.douglasmacrae.ca
black_doug is offline   Reply With Quote
Old February 18th, 2011, 03:38 PM   #11 (permalink)
Either:
  1. Leave the body as is.
  2. Do a bunch of work to modify your tele body so it won't take a tele neck.
  3. Spend a bunch of money to get a tele body that won't take a tele neck.
then, after you've done one of the above, get a new tele pickguard with strat-style heel.
Unless you have a 22 fret neck -- in which case, the overhang will probably cover the gap and you won't have to do or buy anything.
There. Fixed that for you.
_________________________
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.”
Mark Twain
crackpot is offline   Reply With Quote
Old February 18th, 2011, 03:49 PM   #12 (permalink)
4. Bolt the neck on and play it--don't worry about the pickguard.
[I]"Whoops." -Waylon Jennings[/I]
Mark Moore is offline   Reply With Quote
Old February 19th, 2011, 02:53 AM   #13 (permalink)
TeleJedi's Avatar
Thanks everyone! How about getting a new usacg strat body with tele routing? I only want the bridge pickup rout so I can do without pickguard.
Old February 20th, 2011, 05:48 AM   #14 (permalink)
TeleJedi's Avatar
Where can I get a pickguard that matches the heel shape? By doing that, I won't need to modify body or neck if the pickguard covers the little gaps.
Old February 21st, 2011, 11:17 AM   #15 (permalink)
Great video, you can actually see that Eric didn't worry about the gap at either side of neck pocket...
I wouldn't either.
I have always loved that tune and only now discover it's a Tele...
lynxrat is offline   Reply With Quote
Old February 21st, 2011, 11:22 AM   #16 (permalink)
KokoTele's Avatar
You'll have to get one custom made. The fact that your'e in Singapore may complicate things a little, but I'm sure most manufacturers will ship to you.
WD Music Products is my favorite. http://www.wdmusic.com/guards_guitar_index.html
Parts & Pickups
Old February 21st, 2011, 12:56 PM   #17 (permalink)
No mod is needed to put a strat neck on a tele. Just bolt it on.
I didn't even have to modify the pickguard, like everyone has said if the neck has a 22nd fret everything it covered and looks great.
I love it. I've played strats for 10+ years and a strat neck on a tele is so comfortable yet sounds so different.
Jawknee5 is offline   Reply With Quote
Old February 21st, 2011, 02:04 PM   #18 (permalink)
black_doug's Avatar
What do you like about it? Is it a soft V like EC likes?
- Bob Dylan
