Old January 25th, 2011, 09:10 PM   #1 (permalink)
'72 Telecaster Thinline Reissue Low E String Problem
Hey guys,
I have a '72 Telecaster Thinline Reissue and the Low E strings is awfully close to the edge of the neck, to the point where it will slip off if I'm not careful. I was wondering if there is anything I can do to fix this. It looks like a bridge problem, thanks for any help.
ugottjon is offline   Reply With Quote
Old January 25th, 2011, 11:12 PM   #2 (permalink)
boris bubbanov's Avatar
Welcome!
Combination of 2 issues:
1) The Hardtail Strat bridge is 2 + 7/32nds inches string array; the widest of all Teles;
2) This particular guitar's neck is not perfectly aligned and needs to come back a little. Check out the thread by TDPRI member "carzee" about neck adjustment under tension.
Don't go too far though. I'd rather a fat E string close to falling off than the treble E string.
Some other solutions include a narrower string array at the nut (new cut) and/or a neck with less roll to the board and/or fret edges.
Or a Custom bridge with a slightly narrower string array. Check out Dale Clark's 3 barrel plate and saddles for hardtail Strat http://www.glendaleguitars.com/trem%20blocks.htm. Or check with Marc Rutters.
Old January 25th, 2011, 11:24 PM   #3 (permalink)
Perhaps I should have specified that the model I have has two humbucker's in it.
This one:
http://www.guitarcenter.com/Fender-C...13-i1146393.gc
Also could you link me to the thread, I can't seem to find it.
Thanks.
Old January 27th, 2011, 11:55 AM   #4 (permalink)
bump
Old January 30th, 2011, 08:54 PM   #5 (permalink)
bump
