Twisting wire together to reduce interference...
I'm wondering if the polarity of the wires matters when you are twisting them together to reduce interference? For instance, do you need to twist a negative (ground) wire with a positive (hot) wire, or could you twist two positive wires together and get the same result? How about two negatives and a positive (like the combo coming out of a tele bridge pickup).
Also, what is this effect called when you reduce interference by twisting wires together? I want to look it up but I don't know the its name. Thanks for you help! |
Twisted pair cabling. It's an 'ol telephone cable trick
You would have to twist the pair of an individual circuit, id est, the positive and neutral of ONE pickup, for it to have effect. You could say in theory it works with wire like a RW/RP pup works in a set, and only works with AC. Last edited by sjtalon; January 22nd, 2011 at 05:44 PM. Reason: grammer redo |
For a twisted pair to have best results, both leads should have equal and opposite current flows. Twisted pair used to be readily available by the inch or shop spool, but some folk take two wires of same gauge with different insulator colors, anchor one end of the pair in a vise, clamp the other end in an egg-beater drill, and whirl slowly until they get the twist they want.
I was going to twist the input jack wires because I heard that helps, but I hadn't heard about twisting the pickup wires. Is that something people do? I guess it would just be the positive and negative twisted together? What about a 4 wire humbucker?
#5 (permalink) | |
Bob "You've got a hole in your soul if you don't dig the Blues" |
I'm no expert, but I'm pretty sure that twisting the input jack wires is an attempt to have the ground wire act as a shield by wrapping itself around the hot wire. It would be even better if you left the hot wire straight, and totally wrapped it in the ground wire for it's entire length. Kind of like how George L cables are constructed...the ground is 'weaved' around the entire length of the cable effectively shielding the hot wire contained in the centre. So the ground 'shunts' away any RFI/EMI and reduces noise.
I'm sure there are other factors to consider. JMHO.
The best thing you can do to increase your value as a guitar player is learn to sing. But most guitarists don't want to hear that, so we mod instead...hoping it will compensate. |
Twisting wires to reduce audio hum is only effective with very long wires. If you've got something that is picking up a nearby strong radio station then it can help. On the other hand, it can't hurt either. It's the sort of thing you can experiment with without consequence.
Twisting is effective even with short runs, and mutual twists are far more effective, especially in a balanced run, than trying to make one side the shield.
If you wish to make one side a shield, go to full-shield cable - it's different. The theory makes it obvious, please feel free to look it up.
"Everything is a tone control" -donh- |
I always twisted to feed them through the body routes.
The sound man in our band INSISTED that the lights / PA and stage a/c was separated and wrapped a certain way to avoid interference. ..so the wrapping at least works for sound and power cords because we never had 60 hum or buzz. ..or got shocked. |
Two wires running parallel to each other in close proximity with current passing through one or both can set up an EM field. Twisting them together effectively contains the EM field. It does not have to be AC to be effective.
Telephone wires are bundled in groups of 25 pairs, each 25 pairs are sub-grouped into five pairs. Each pair is twisted and there is a slightly different twist (turns per inch or foot or whatever) so that no two pairs of wires in a bundle will lay side-by-side with the same twist to prevent creating an EM field between adjacent pairs. This was done to prevent cross-talk in cable bundles. If cross-talk does occur, it is generally due to some defect, or potentially water in the cable. |
#12 (permalink) | |
I've been a broadcast engineer for 30+ years. I've seen every type of audio distortion that ever was, and hum is probably the most common. Almost every case of induced hum is due to poor practice, not materials issues. |
#13 (permalink) | |
If I find that condition, I fix it! They way I wire them, it's a non-issue. As it should be. And pickups are a balanced kinda thang. They are typically wired into electronics in an unbalanced configuration, but that is a subject for another thread. I am sorry that twisting wires fails to work for you. some of us find it really really useful anyhow.
#14 (permalink) | |
I do not think twisting makes much, if any difference, but I did (also) say earlier that there's no harm in experimenting with it. It's so easy to over complicate this stuff, it's a wonder anybody would take up instrument repair or building as a hobby. Knowing what advice to follow and what to ignore is strictly personal preference, and by all means ignore my advice any time it seems to be less than helpful. I don't have all the answers, but like most here I do have a fair amount of experience that might be useful to someone on occasion. I'm also not the one investing time or money in your project, so the end result is always your work. |
This is quite a divergent set of posts. Linked below is an explanation I posted on twisted pair wiring nearly 3 years ago. I hope it helps converge this topic.
Twisting wires help reduce tele huml
Best regards, Terry Downs http://terrydownsmusic.com Equine quadrupeds may be coaxed to the reference of specific gravity but may not be compelled to imbibe thereof. |
#16 (permalink) |
Thanks for the helpful post Terry,
I am using noiseless pups, and I do plan on shielding the guitar, so I'll go ahead and twist the wires too. One quick question though... You said that the opposite polarity of the two twisted wires is essential for the hum reducing effect. So what happens when you have three wires? I'm wondering because I don't know what to do with my bridge pickup, which has a positive and negative wire, as well as a ground wire for the baseplate. Do I twist the positive and negative wires together, and then run the single ground wire separately alongside the twisted pair? Or can I still just twist them all together as a trio? Thanks again for your input! |
#17 (permalink) |
You have noiseless pickups, why are you going to shield ?
I think some people go nuts with this shielding stuff just because they read you should do it ( as if you HAVE too). SOMETIMES shielding has effect on the pickups tone, so it's one of those things that you should only do if necessary. Twisting wires and some of the other voodoo stuff you hear about gets blown out of proportion I feel. Too each his own but the best thing to do with a guitar is play it. Last edited by sjtalon; January 26th, 2011 at 10:00 AM. Reason: spelling |
#18 (permalink) | ||
