Old October 8th, 2010, 01:59 PM   #1 (permalink)
Middle pickup, only through a push-pull pot?
Hi
I've got an MIM tele with a four way mod. What i want to do is add a middle pickup (probably some kinda lipstick pup). I dont rlly want to get involved in a five way switch but i can't find a diagram for how to wire it with a push-pull pot. any help?
Thanks
Iz
Izzyg is offline   Reply With Quote
Old October 8th, 2010, 04:47 PM   #2 (permalink)
sjtalon's Avatar
easy one
Just wire the p/p switch terminals like this:
__Pot/SHAFT end___
X A
X B
X X
A- will be the middle pickup positive wire.
B -would be a added wire to the volume pot terminal ( same one that has the wire from your selector switch)
X left empty.
When you pull the knob UP, the middle will be added to whatever you have going with the selector switch.
Old October 9th, 2010, 09:14 AM   #3 (permalink)
awesome, thx alot. now to get a good pickup combination...
