Matching Bridge Saddles to a Compound-Radius Fretboard
Yeah, that's my question/lol...
I've learned just about enough about doing my own setup work to be dangerous and I'm curious to know how one goes about matching bridge saddles to match the fretboard radius when using a compound neck. (My apologies for the terribly constructed sentence. This issue is sure to continue.) Any of you have any experience with this? For my next project, I'm looking to use a 10-16 compound radius fretboard. Do I match it to the end of the neck that is closest to the bridge? The mind boggles. |
try and you'll see, i guess...... nut: 10
21 fret: 16 12 fret must be about 14½ so the bridge will be around 19 inches radius, that makes sense to me hope it helped!
I make Guitars & effects and I Mod amps+much more |
With a compound radius fingerboard, he "string plane" gets flatter & flatter as you go up the scale. So, there should be very little curvature at the bridge -- when you rough it in. You will still have to twiddle with each string just a bit to get the best "feel" up and down the scale.
#4 (permalink) | |
![]() Tele-Meister
The answer is that you don't need to pay the slightest attention to what the theoretical radius should be at the saddle, you simply adjust each string until the action and intonation are correct, and the saddle radius will take care of itself.
![]() The TECHNOFRET Alternate String Anchoring System for acoustic guitars ... get rid of your bridge pin problems forever... ... Click here to check it out... |
#5 (permalink) | |
This can however mess up intonation. You may need saddles with more "compensation" with a highly conical radius board than you would with a 7.25 straight board neck to get good intonation but you gotta take it one step at a time. Don't change brand or type of saddles until you are certain the intonation cannot be tweaked enough and/or lived with. |
![]() Formerly known as Eryque Doctor of Teleocity
I never bother with using a radius gauge to set the action. I simply measure they action for each string at the 12th fret and set them all equal. Sometimes the lowest strings need to be just a hair higher to avoid buzzing, in which case I compensate as I set each string.
One friend said he preferred the feel of his guitar when he set the tops of the strings to the same radius instead of the bottom, but so far he's been the only person who's said that to me. |
#8 (permalink) | |
![]() Tele-Meister
The answer is as before, you don't even have to consider the radius at the bridge , it will self-determine once you set the action and the intonation.
