Old July 22nd, 2010, 02:37 PM   #1 (permalink)
radius setting quick question
Hi Guys
Apparently I set string height at 17 fret before I set radius which string do I set Height from?
thanks
Kilf is offline   Reply With Quote
Old July 22nd, 2010, 03:26 PM   #2 (permalink)
Formerly known as Eryque
KokoTele's Avatar
Usually, setting the two outside strings works best.
I usually just use my ruler and measure each string individually, which will get them to the radius of your fret board.
My goal is usually 4/64" on the low side and 4-5/64" on the high side at the 12th fret.
Parts & Pickups
www.kokoteleguitarworks.com
Old July 23rd, 2010, 03:15 PM   #3 (permalink)
telex76's Avatar
I also just set height on all strings, if they are right then radius is right.
telex76 is offline   Reply With Quote
