Shielding help
This is a multiple part question. I'm trying to do the shielding mod that I found at GuitarNuts.com. So here goes.
1. Does opening up my guitar void the warranty? 2. The black wires on my MIM Tele are each soldered onto these odd clips that screw into the body of the guitar. When I put in the copper shielding, do I not want this the make contact with it? It seems like it would create a ground loop, right? http://i249.photobucket.com/albums/g...g?t=1278719237 3. While inspecting the wires I found that this white wire was touching this little brown component (capacitor?) and seems to have gotten burnt. This is bad right? Should I clip off the burnt part and re-solder it? How can I prevent this from happening again? http://i249.photobucket.com/albums/g...g?t=1278719325 |
1. No, but obviously butchering anything up in the process of modifying it can.
2. No such thing as a ground loop in a passive electric guitar circuit. Though there may certainly be some useful tips at the Guitarnuts site, some things seemingly stated with certainty there should be taken with a tablespoon of salt. Ground loops in guitar circuits for example, are a completely unfounded and incorrect myth. 3. An aesthetic blemish, nothing more. No practical impact whatsoever. And finally, shielding the control cavity of a Tele will very, very rarely have any noticeable effect in the big picture. It won't hurt, but it can only help in a very particular set of circumstances of a minor type of hum, which is not typically the source of hum most people are trying to eliminate. More often than not, it's a harmless, yet misguided effort. Plus, it looks like your cavity is already shielded. Albeit generally a mediocre shielding job, there is not typically a great deal of improvement that will be noticed with an improved nickel or copper shielding. |
Shielding paint - the common black shielding paint that I believe is used standard on these. If it weren't shielding paint, then there would have been no reason for them to have screwed ground terminals to the cavities to begin with.
#5 (permalink) | |
What happens if I don't ground the shielding paint?
Telecaster > Mustang Floor > FOH/BJr III/HRDx III/V1512T |
#6 (permalink) | |
http://www.tdpri.com/forum/just-pick...und-wires.html What you are not grounded??!! (kidding!) |
Your wire, is it burned through? If not, it will be alright. If the wire is exposed you can tape it, replace it. Probably touched while soldering. The shielding paint was most likely applied before the finish for better adhesion, therefore over sprayed. Probably can't improve much on what you already have.
#9 (permalink) | |
When I installed new pickups, I didn't ground the shielding paint. I just ran the pickup ground wires directly to the Volume pot. What are the hazards of not grounding the shielding paint?
