Old May 24th, 2010, 03:08 PM   #1 (permalink)
Fret Crowning Question
I'm getting ready to do my first fret level on my Squier Tele and I plan to use the method Ron Kirn posted here.
I don't have a crowning file yet and I'd like to know if it's okay to level now, play the guitar without crowning, and crown the frets in a week or 2 when I get the file. I guess I don't really understand the importance of crowning. I'm not doubting that it needs to be done, I just don't get it. What will happen if I don't do it?
Is it something that just makes the frets feel and look nicer or is it absolutely essential for intonation, sound, etc?
samato is offline   Reply With Quote
Old May 24th, 2010, 03:26 PM   #2 (permalink)
It's absolutely essential for intonation, sound, etc. Aside from feeling like crap as you slide up or down the neck, your strings will not be leaving from the center of the frets, and can even end up with a slight buzz as it breaks over the back corner and vibrates along the flat.
I see no reason at all to rush things until you're ready to actually complete the job. All you'll succeed in doing is making your guitar less playable for the interim period than it is right now. If you're going to bother doing it at all, do it right.
David Collins is offline   Reply With Quote
Old May 24th, 2010, 03:29 PM   #3 (permalink)
The frets should be crowned so that the center of the fret is the edge on which the string bends. If you don't crown, it will bend over the back edge of the flat (levelling flattens the frets) and you will have some buzz issues as well as some very slight intonation issues.
EDIT: David beat me to it =\
LocustPlague is offline   Reply With Quote
Old May 24th, 2010, 05:02 PM   #4 (permalink)
Okay, thanks guys. Makes sense. I can wait.
Slightly off topic but do you think it would be okay to use 120 grit instead of 180 for leveling? I found some 120 that fits for cheap.
Old May 24th, 2010, 05:36 PM   #5 (permalink)
KevinB's Avatar
Yes, I guess you could especially if you "go light" with it.
But I have to ask, how much does the correct sandpaper cost, a little over a buck a sheet?
Old May 24th, 2010, 05:51 PM   #6 (permalink)
Ronkirn's Avatar
David is dead on.... what happens is when the fret is flat on top, the point at which the string becomes free to vibrate is shifted forward a rather substantial distance.
While the intonation problems will be virtually unnoticeable on the first few frets, say to around fret 5, as you move further up the neck, that "shift" becomes a larger percentage of the distance to the next fret, by the 12th, it will be so far off, dogs will be howling, might even come gnaw your picking hand off to getcha to stop making all the noise.
Remember, when working on your guitars, patience is the key... wait for it to dry, wait until you understand, wait until you have the right tool.... you'll be glad you did.
There is nothing like the joy of learning how to do something, doing it, and having it improve your guitar... and there is not many things as disappointing as trying something you aren't ready to attempt, screwing the pooch, then having to learn how to fix what ya broke.
Ron Kirn
“Silence in the face of evil is itself evil:
God will not hold us innocent.
Not to speak is to speak. Not to act is to act.”
— Bonhoeffer
www.ronkirn.com
Old May 24th, 2010, 05:59 PM   #7 (permalink)
ThermionicScott's Avatar
120 grit to level? Are the frets worn halfway to the wood?
I generally use 400 or 600 grit -- less roughness to worry about when polishing up the frets after recrowning.
- Scott
Wound thirds are my anti-wank.
ThermionicScott is offline   Reply With Quote
Old May 24th, 2010, 06:31 PM   #8 (permalink)
Yeah, I can't believe the coarse grits some of these guys use, but maybe I'm out of touch, since I prefer to replace 'em if they need such extreme leveling to all be even.
And then when I replace 'em, I start out with 800 grit (but my fret installation process is very slow. So any bragging rights get canceled out with that)
Soapbarstrat is offline   Reply With Quote
Old May 24th, 2010, 06:41 PM   #9 (permalink)
zack78's Avatar
Can you post link, please?
zack78 is offline   Reply With Quote
Old May 24th, 2010, 06:54 PM   #10 (permalink)
Ronkirn's Avatar
http://www.tdpri.com/forum/tele-tech...ele-101-a.html
rk
— Bonhoeffer
www.ronkirn.com
Old May 24th, 2010, 07:06 PM   #11 (permalink)
zack78's Avatar
Originally Posted by Ronkirn View Post
hello Ronkirn
this is AMAZING stuff
Thank you very much for this tutorial
Old May 24th, 2010, 08:43 PM   #12 (permalink)
boneyguy's Avatar
I know Ron has already given you the link but I thought I'd point out that his thread on fretwork is a 'sticky' so it's always at the top of this 'Tele Tech' page.
I am the center of the universe and so are you.
boneyguy is offline   Reply With Quote
Old May 25th, 2010, 12:49 AM   #13 (permalink)
Thanks for all the info guys. I'm doing my best to be patient and wait until I have the tools and a better understanding of things.
Old May 25th, 2010, 08:34 PM   #14 (permalink)
zack78's Avatar
thanks
tele squier twang user
Old June 2nd, 2010, 05:26 PM   #15 (permalink)
Well I got my crowning file the other day so last night I tried my first fret level. I thought I was doing fine but when I finished and put it back together with new strings I didn't get the results I was hoping for. I still have some buzzing on the open A and D strings and the action is not even that low.
I'm trying to figure out what went wrong. Maybe I didn't have the neck flat enough when I leveled? Oh well, back to the drawing board.
Old June 2nd, 2010, 05:40 PM   #16 (permalink)
Colt W. Knight's Avatar
Could be your nut, saddles adjustment, loose truss rod, or overall setup.
the now mandatory =====>
Old June 2nd, 2010, 05:47 PM   #17 (permalink)
Definitely not the truss rod. I kind of don't even want to bother with a setup because if the action is already high and it's buzzing what good would it do? I've tried the neck completely flat, a little relief, etc. to no avail.
I'm not saying the leveling didn't do anything positive, it is slightly better than before but I guess I was just expecting it to play the way I want and it's not yet.
Old June 2nd, 2010, 05:59 PM   #18 (permalink)
Did you check if the neck was straight before levelling?
I don't mean to be condescending, but it doesn't seem like you knew all the ins-and-outs of guitar setup before getting into this.
If the neck is straight now, and the frets were levelled properly, I would suspect low nut slots for the A and D strings. Fret the strings at the third fret and check if there is a gap between the string and the first fret.
- Scott
Old June 2nd, 2010, 06:23 PM   #19 (permalink)
[QUOTE=samato;2549291] I kind of don't even want to bother with a setup because if the action is already high and it's buzzing what good would it do? QUOTE]
Without a proper setup, frets leveled on a PLEK would buzz. Which includes
Proper neck relief
Proper Saddle height, intonation, radius
Properly cut nut
+ leveled, crowned, polished frets.
Sometimes, neck shims have to used in order to facilitate proper playing action.
Old June 2nd, 2010, 06:26 PM   #20 (permalink)
I checked if the neck was level before starting to level but I could have been wrong as I'm not experienced at doing this. As far not knowing the ins and outs of this, DUH!!!!!! If I knew everything I wouldn't be here talking about my poor results would I?
I've been reading and researching as much as possible for quite a while but at some point you just have to do it and that's where I am with it. I'm not surprised I didn't get the results I was looking for on the first attempt. Things never go that easy for me.
