Considering switching to 11 guage flatwounds
I just got my guitar back from the shop after having it foolishly set up for 10s. I am very intrigued by 11 guage flatwounds, but I don't have the money or patience to spend and wait for yet another set up.
If I made the switch, would the neck need re-adjusting? How about the intonation? Thanks a lot! |
Which set would you choose 11/50 or 11/52?
I went from 10/46 to 11/50 with no trussrod adjusting needed. Just changed the saddles a bit because I changed the height, but I'm not sure the gauge change alone would have required to set the intonation again. I have a rosewood neck and maybe a maple neck is more 'elastic'. Also, 11/50 are hard to find so I will go to 11/52 definitely. I could give you some news at this time. The new strings are ready and the old ones quite dirty so it will be quite soon. |
I put 11-50 flatwounds on a Fender HH tele...
Which became my new "Jazz" axe:
Remember those Aztec Gold HxH teles that MF blew out a while back? - Arched mahogany body - Set mahogany neck w/ RW fingerboard - Uninspiring DiMarzio p/ups Now it sports a creme LP-ish pickguard to to with the creme bezels, a Duncan Seth Lover in the neck, and a "59 in the bridge. New CTS pots, CRL switch, and now I've got instant Wes with no feedback beefs! Flat wounds on a Tele for jazz rule! :D -Bill
Greetings from Shell Beach... |
Thanks for the replies, guys. How can you tell if a guitar needs a truss rod adjustment or a change in string height? All I know is that you have to adjust the string length to set the intonation.
#5 (permalink) | |
"People assume that time is a strict progression of cause to effect, but 'actually' from a non-linear, non-subjective viewpoint - it's more like a big ball of wibbly-wobbly... time-y wimey... stuff." |
Right, thanks a lot. I think that I'll just go for it and buy 11s on Monday and see what happens.
My guitar is an American Standard, so it has the 6 strat-like bridge saddles instead of the older 3 peice brass ashtray thing. |
changing strings and new setups
i've never gotten a pro setup.
i understand, though, that if you change strings from say, 10/46 to 12/52, you will likely need a little tweaking. my main tele, 6 months old, came set up with 10s. right now i'm playing 12s tuned down double flat. intonation and nut problems are no sweat to fix, but i've never tweaked a trussrod before. string height seems fine, but do i need to worry about neck problems even if my strings are two steps flat? |
Good tip if you have to tighten the truss rod is to remove the adjusting nut completely and lubricate it with light oil or vaseline before tightening it.Do only a 1/8th to 1/4 turn at most
The tip comes from Dan Erlwine's book -- Guitar Player Repair Guide--and I would recommend it most highly. Good luck with the flatwounds , I tried a set on my 335 and they are no.1 for jazz tone . The 11 set I fitted felt very very stiff compared with roundwounds and if that corresponds to increased neck strain you will need a truss tweak. Interestingly the D'Addario site lists the string tension for all sets ( as they do on the packet) so it may be interesting to see what they quote for their jazz string sets. Another tip ( my own this time) is that we are all familiar with string guages in 100ths of an inch eg 009 - 042 so why not use a suitable guage string offcut as a feeler / sighting guage when measuring relief. Most Fender strats are setup with 012" relief at 7th fret. Mike |
The string tension thing fascinated me me so I took a look at the D'Addario site and worked out the following numbers.
String pull on a set of roundwounds 10-46= 103.6lbs. " " 11-49= 118.6lbs. " " flatwounds 11-50= 137.3lbs. so not a major difference going from 10 to 11s but an extra 33.7lbs pull on the neck with flatwounds, so I guess a truss rod adj would be necessary Mike |
I had flatwound 11s on a tele for a while; they sound great. Now using daddario flatwound 10s which more or less compensate for the inherent greater tensio-they almost play like roundwound 11s. Just my .02[/code][/quote]
I use Thomastik-Infleds...
On my MIM Squier tele, .010 -.044's...I like the feel, they bring me back to the 60's when I was learning to play. Great for surf or 60's music, but bending is a chore.
They are expensive, but Pyramids are supposed to be not as stiff. |
