String Snapping
As embarrasing as it appears, I have broken several strings with my new Custom Deluxe Custom Shop Tele
If the string is breaking up by the tuner it is because when you initially tighten down the retaining knob on the tuner it puts a dent in the string. Then when you release the lock the string probaly moves out slightly..this leaves a weak spot in the string causing it to snap. You should not have to loosen the retaining knob to tune the strings. i usually get about a 1/2-3/4 of a string wind around the locking tuner when I initially tighten it. Should be plenty to retune without loosening.
Sounds like you are under the mistaken assumption that tightening the locking wheel in back keeps the tuner from turning.
What it does is lock the string in the hole. Just run the string through the hole in the tuner post, tighten the wheel and then tune normally. Flynman is right. Loosening that wheel (retaining knob) is causing your problem. You only loosen it to change strings. S Mac |
Tuners
Macatt & Flynman,thank you both very much!
You should only be embarrassed if you did not ask the question. If there's a problem with a guitar, somebody here will know the answer. This is the best forum on the Web!! Good luck with your new Axe.
She is a beaut!! My favorite color right now!
"The old worn down veterans still gather at the Hall,sitting around a table with the ghosts who gave all" http://www.ourstage.com/profile/nekkidcountry |
