Old May 20th, 2004, 04:32 AM   #1 (permalink)
FraKo's Avatar
3rd string output
I'm settin' up my new Standard MIM, and the 3rd string has a very higher output than the other strings (followed, as close 2nd, by the 4th string), expecially when I play thru the neck pup. Following the Kinman.com instructions, in this moment the gap between the pup and the 1st & 6th strings is approx. 2 mm (5/64"). I can't notice a big difference if I either lower or raise the pup, the 3rd strings also has a higher output.
What can I do?
FraKo-the-gnome
1/2 Member of the Double Bound Telecaster Owners Club
FraKo is offline   Reply With Quote
Old May 20th, 2004, 05:32 AM   #2 (permalink)
rebelern's Avatar
Re-Kinmans!
Frako,
Mine have even output, both the neck and bridge, are set at 4/32" bass side, and 3/32" treble, when fretted at the "12th" fret!.
Hope this helps,
Ernie.
rebelern is offline   Reply With Quote
